Just recently became an airstream traveltrailer user. There so many questions that I need to know before I use this 1976 26' Argosy. When I bought her it took two days just to get the signals and lights to work. I do have a question about the charging of the battery while towing. My 1990 std. Chevy PU did not have a trailer 7 pin plug that uhaul installed. They did not run a wire from the alternator to the plug. Where could I find out how to do this and does this line need to be fused. What gauge wire. etc. Thanks to all that answer..
welcome to the forum! you are at the right spot for questions.
you will need 10 gauge wire, with at least a 30 amp fuse in line.
on your chevy's passenger side fire wall there should be a terminal for accessory power. it should be under the plastic cover that houses the fuel pump relay etc.
if you have a service manual for your truck it will be pictured there.
My buddy is installing my Jordan brake controller on Tuesday and I noticed that the guy who installed my receiver and the 7-way plug, ran a 10awg wire to my 30A fuse panel. My truck was prewired, but not for a 7-way plug(so he added 1 wire). I thought that the wire he was adding, was for my trailer brakes, but if I'm understanding this link, he ran the 10awg for my trailer battery charging.
If I'm wrong, please let me know.
Also, does Chevy put a 20A auto-reset CB inline for the trailer brakes?
I'm looking at the manual and my truck came with the Basic trailer wiring package, a 6 wire harness.
As I was a total novice(didn't even have the trailer yet) the guy ran the wires to that 30A fuse that you have the arrow pointing to.
He ran 2 wires from the plug up underneath to under the hood. What I now don't know is how he terminated them.
This is my mystery. Again my buddy, who's a good Chevy mechanic, is coming by Tuesday to install the Jordan brake controller and he's also going to add the 20A auto-reset CB.
I'm just trying to understand how it's all wired. If you're able to explain, great, if not I'll find out on Tuesday.
When I set up our Suburban we put in circuit breakers on both lines and put in a heavy duty starter contactor wired to a key on source so it would drop out the charge line so we can stop overnight at Walmart without fear of running the tow battery down.
Good thought there! As I try to remember to unplug the trailer cord at night when just sleeping over, this is a nice safety valve for those laps of brain function.
