Old 08-06-2007, 08:18 AM   #1
1986 32' Excella
vledder , drenthe
Images: 8
wiring impulse brake controller
I have here a 4 wire impulse brake controler.
blue wire to trailer brakes ?
red wire (thin) to stoplight switch ?
Black wire ?
White wire ?
overhere black is normale used for ground but I don't know if that's the same in the US
Remco
remcolent is offline   Reply With Quote
Old 08-06-2007, 08:27 AM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Make and model of the controller is needed since the wiring in not the same from manufacturer to manufacturer.
Michelle TAC MT-0
Sarah, Snowball
Old 08-06-2007, 08:48 AM   #3
Images: 59
Blue - power to trailer brakes
Red - enabling power from brakelights
Black - 12V power
White - ground/earth
For Tekonsha Prodigy P3 and other models.
Over here, black is ground in vehicles, and white is ground in trailers. Red is 12V+, except where white is ground, then black can be 12V+. So it's not uncommon to see a black coming from the battery, changing to a white where the ground is located.
It's all part of our happy-go-lucky nature.
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
Ok, I need a brake controller Chuck Brakes & Brake Controllers 6 06-07-2002 12:43 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Electric Brake Wiring JW84345 Brakes & Brake Controllers 3 03-26-2002 09:40 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
