Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 07-20-2005, 09:38 PM   #1
buckeye
Profile:
Wiring Electric Brakes
I want to rewire my electric brakes for my trailer. I have removed the wheel to change the bearing, and know notice that instead of blowing fuses, the magnet does not work when I step on the brake or use the electric brake module manually.
I was wondering if all I need to do is run a wire from the 7 way connect on my truck (the one for the electric brakes) to the brakes and bring the other wire back to my truck (to the negative). Is there something else that has to be done? Unfortunately I can not trace the wires once they enter the trailer and I can not determine if the wire does anything else when it enters the trailer.
Thanks.
buckeye is offline   Reply With Quote
Old 07-21-2005, 08:39 AM   #2
joatmon
Profile:
The belly skin must be dropped to access the brake wiring.
Running a new wire outside the belly skin is NOT recommended as it would leave the wiring unprotected against road & campground hazards.
Your magnet may be bad. Disconnect it, and check its resistance with an ohm meter. The resistance should be 3-4 ohms. Check the wiring for chafing where it exits the belly skin near the wheel.
joatmon is offline   Reply With Quote
Old 07-21-2005, 09:35 AM   #3
buckeye
Profile:
I ran a jumper wire from my truck to the brakes. And brakes work perfect now. I think I my like you say run a new wire, but thru the trailer not to have it exposed. Wire is old brittle, insulation around wire cracks when I move it with my hand.
I was just making sure when I run a new wire I wasn't missing anything, like an extra wire I can't see.
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 06:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 08:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 08:56 PM
conversion from vacuum/disk to electric brakes excelladep Brakes & Brake Controllers 2 05-30-2002 12:54 PM
Electric Brake Wiring JW84345 Brakes & Brake Controllers 3 03-26-2002 10:40 PM
