Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 03-01-2007, 09:17 AM   #1
The Flintstones
The Flintstones's Avatar
Profile:  1970 27' Overlander
Houston , Texas
Wiring Breakaway Switch
Hi all,
How do you wire the breakaway. From the intructions I believe I need to splice into the 5 pin cable that plugs into my tow vehicle (the blue wire) then somehow connect to the 12v battery in the rear? I did search first but did not find much.
BTW its the model from vintage trailer supply which matches the rusted one on my AS.
thanks
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 03-01-2007, 10:53 AM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
You can hook up 12v from the 12v charge lineat the tongue to the brake line.
Old 03-01-2007, 11:35 AM   #3
The Flintstones
Houston , Texas
thanks
so I cut and splice into main cable, is that the common practice for attaching breakaway. I'm just not sure about cutting into the main cable. It also says to make sure its unattached from the tow vehicle as it can damage break control. Is that just for the initial wiring of the switch, how can it damage it?
thanks
James
____________
1970 Overlander
Old 03-01-2007, 11:49 AM   #4
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
Seems to me that on my '73 it's wired to the hot lead that goes to the electric jack, which in turn comes from the 7 wire connector inside the trailer. I'll try to take a look tonight and post again.
To lodge all power in one party and to leave it there is to insure bad government. -- Mark Twain
www.nesa.org
Air No. 6427
Old 03-01-2007, 12:15 PM   #5
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
yeah, mine is that way. no need to cut or splice; there is a second wire from the brake circuit already fished up into the a-frame, and another lead that connects to the charge line that provides +12v. the breakaway switch connects these wires when the pin is pulled, sending unregulated +12v to the brakes.
since the umbilical connects to the brake line as well, if the breakaway switch is actuated, that would send 12v up the umbilical's brake line, back toward the brake controller, which isn't designed to get zapped with the full amperage of the battery from that direction. In a real-life situation, this wouldn't happen, because the pin won't get pulled on the breakaway switch until after the umbilical has already seperated from the tow vehicle. (make sure that the breakaway cable is longer than the umbilical so that it only actuates if the trailer is completely disconnected from the tow vehicle; if its still attached, you want to be in charge of the brakes).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Need wiring diagram for a 1975 26 ft Argosy ... Hayseed Airstream Motorhome Forums 9 10-06-2006 11:17 AM
Breakaway switch bhsl8 Brakes & Brake Controllers 26 10-06-2003 04:09 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 06:03 AM
Electr. Tongue Jack Wiring?? roessler Jacks, Stabilizers, Lifting and Leveling 12 07-17-2002 12:00 PM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 03:16 PM
