Old 12-17-2004, 06:34 PM   #1
Cruiser's Avatar
1952 25' Cruiser
Dummerston , Vermont
Images: 45
Wiring brakes
We just re wired the brakes on our 52 Cruiser. Prior to the rewiring...the progidy brake controller could be set for an average of 6-7. Now, however, it will not go above 3.7. What have we done wrong...any suggestions.
Ken and Doug
"Life is not so bad if you have plenty of luck, a good physique and not too much imagination." C. Isherwood
Cruiser is offline   Reply With Quote
Old 12-17-2004, 08:32 PM   #2
Images: 59
It's possible you accidentally wired the magnets in series instead of parallel.
Old 12-18-2004, 09:01 AM   #3
Cruiser's Avatar
1952 25' Cruiser
Images: 45
How do we check to see if its in series rather than parallel? (As you can see, I am a novice at this.) Ken
Old 12-18-2004, 12:08 PM   #4
Images: 59
Did you make a drawing of the wiring connections before you replaced the wiring? It's also possible that you have a bad connection.
You should have the brake wire from the tow vehicle connected to each brake at a common point, not in a 'daisy chain'. You may also have a poor ground connection. It may be best to take it to a trailer shop and have someone else get dirty trying to track it down.
Old 04-24-2005, 02:22 AM   #5
The voltage will be around 12 volts across each magnets with breakaway pin pulled. If wired in series the voltage will be 6 volts approximately. Another way to test is place an ampmeter in series with your battery and pull the breakaway pin. The current is around 10 amps on my 70 overlander
FrenchBern is offline   Reply With Quote
Old 05-24-2005, 05:07 PM   #6
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Brakes have me stumped
Maybe someone can help. I don't think I have brakes on the trailer when I push the brake pedal. This is confirmed by not having power at the vehicle 7 plug connector for the brake and no light on the brake controller when the brake pedal is pushed. Also no power in the wire from the brake controller (red wire) to the vehicle non-powered brake connection (on my 2004 GMC it's the light blue wire. I can't say that I know it ever worked since it was wired last summer as I probably thought it worked but didn't really ever check it. Now I really wonder. The brake controller worked on other vehicles including the light on the brake controller when the brake pedal was pushed.
The manual level on the brake controller does make the light on the brake controller come on and there is power at the 7 plug when the manual level is used. (however, the brake lights do not come on the trailer when only the level is used to activate the brakes which I am told is normal.)
Any ideas? Brake controller is an older Kelsey about 8 years old. I'm not sure its the brake controller that's the problem. Thanks. Rich
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 05-24-2005, 05:57 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
rich
do you have the adjustment knob turned all the way down? i'd bet your controller is bad.
john
you call them ferrets, i call them weasels.
Old 05-24-2005, 06:13 PM   #8
John: I've tried moving the knob all the way in both directions without any luck. Maybe I'll get myself a new brake controller for Father's Day. The GMC dealer hooked it up for me so I'll stop by and have him look at it tomorrow. $145 for a Prodigy at the local RV store.
Rich
www.compassion.com
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
TV Antenna wiring??? tenrsingr Audio, Video & TV 6 05-06-2002 02:16 PM
