Old 05-05-2013, 01:20 PM   #1
jerryc41's Avatar
1973 31' Sovereign
Shokan , New York
Wiring a Breakaway Switch
What is the proper procedure for wiring a little Bargeman breakaway switch into a 1973 31' Airstream? Let's assume that I do not currently have the correct wiring at the A-frame.
jerryc41 is offline   Reply With Quote
Old 05-05-2013, 01:58 PM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I've never done it and certainly stand to be corrected, but I would think you would just need to bring a decent sized wire (maybe #14 or #12?) via an in-line fuse, from the plus side of your coach battery or batteries to one side of the switch, and then run from the other side of the switch to the brake feed wire on the trailer - once you identify which wire it is !
Are you saying that your trailer does not have a standard 7 pin connector?
If it does, there are lots of diagrams on line to show how it should be wired and which would be the feed wire to the brakes - I don't recall off hand.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 05-05-2013, 01:58 PM   #3
1974 Argosy 20
Kooskia , Idaho
Three possible ways:
1. Find the 12 volt supply wire which will go to your umbilical cord socket. (I think the 73's still used a socket in the front with a two ended umbilical cord). Access to the back of the plug is inside, under a white plastic cover which may be buried below the couch or whatever is in the front of your floor plan. While you are there locate the wire which goes to the trailer brakes. Run a wire from each of those to the break away switch and you will be done.
2. Alternatively, since your trailer originally had a break away switch, see if you can locate the two original wires which went to it. One should have +12 volts on it, the other should activate the brakes when attached to 12 volts.
3. If you have an electric jack that works, the power to it can be your +12 volts, and all you need to do is to find the brake wire line for the other side of the break away switch.
Old 05-05-2013, 02:21 PM   #4
Breakaway switches are wired directly to 12 volts dc and then to the "HOT" wire of the brakes.Make sure you ID the hot side. If not, you will be hooked up to a ground.
If you pull the cable, that switch will burn up very quickly, "IF" the cold side is wired to the ground.
Andy.
Old 05-06-2013, 05:40 AM   #5
jerryc41's Avatar
1973 31' Sovereign
Shokan , New York
Thanks. I have two wires emerging from the A-frame, but they both seem to be dead. I'm running a new wire for the jack, and I guess I'll have to do the same for the breakaway switch. Your info on the 7-way connector will help me find the brake wire, but - big question:
How can I get the wire form the 7-way plug inside the trailer to the breakaway switch at the end of the A-frame?
Old 05-06-2013, 05:59 AM   #6
There is an inspection plate underneath the front end of the trailer.
Remove that plate, and you should find where the front cable connects to the rest of the wires.
Old 05-06-2013, 08:35 AM   #7
jerryc41's Avatar
1973 31' Sovereign
Shokan , New York
Thanks. I'll take a look.
Old 05-06-2013, 09:30 AM   #8
jerryc41's Avatar
1973 31' Sovereign
Shokan , New York
There is no inspection plate - just the smooth bottom of the trailer.
Old 05-06-2013, 10:29 AM   #9
1974 Argosy 20
Kooskia , Idaho
The inspection plates seem to be variable, I have had AS and Argosy trailers with them and without them. So, without it, you have no easy way to get up through the belly pan area and to the rear of the connection on the trailer shell. What I probably would do if I had your rig would be to cut a piece out of the belly pan to make your own inspection area, and cover it up when done with a larger metal patch, screwed in place over the hole you have cut. In other words, make your own inspection plate.
I can't think of any other easy way to do it.
Old 05-06-2013, 05:26 PM   #10
jerryc41's Avatar
1973 31' Sovereign
Shokan , New York
Thanks. I'm trying to figure out which wire inside the connector is for the brakes. Diagrams for the 7-way usually show a blue wire for the brakes, but I have a green in that position. I got the jack working, so I'll tackle the B-A switch tomorrow.
Old 05-06-2013, 06:37 PM   #11
1974 Argosy 20
Kooskia , Idaho
From memory only now....on your year Airstream I think the brake wire is yellow, but don't hold your breath.
Old 05-07-2013, 04:56 AM   #12
jerryc41's Avatar
1973 31' Sovereign
Shokan , New York
Yellow would make sense because one of the two wires coming out of the A-frame looks like it had been yellow at one time. The trouble is it looks like it had been chewed by mice here and there. I could tape the parts I see, but there might be more chewing that I can't see inside the frame.
I'll try to see if the faded yellow wire I have up front is going to the brake terminal in the 7-way. Then I can try to run a new wire from that terminal. I've looked up 7-way connectors online, and there are too many color combinations. Going back to 1973, there were probably no standards at all.
Old 05-07-2013, 09:54 AM   #13
rogerdodger's Avatar
Fresno/Clovis , California
On the old Airstreams, the brake switch is connected between the Blue wire, which is +12 trailer battery, and the Yellow wire, which is brakes. However, do not hook up this way until you have checked with a meter, as you will be applying +12 volts, which could burn up a lot of trailer wiring if some PO has re-wired things differently. When I re-wired my Argosy, I fused the Blue wire at the terminal near the battery. That way, if I made a mistake, I would blow a fuse before I took out internal wiring.
If the jack is working, that is a good point to connect the brake switch. Also, remember not to test the brake switch with the T.V. connected, as this could cause 12 Volts applied to your brake controller, which could burn it out.
Roger
Air# 29488
rogerdodger is offline   Reply With Quote
Old 05-07-2013, 10:50 AM   #14
1974 Argosy 20
Kooskia , Idaho
If you suspect your brake wire, by all means replace it with a new one, perhaps run under the belly pan, well protected with some flex conduit. Those old brake wires are often suspect in any event, and corrosion works it's way up the insulation from the point the wire attaches to the magnets. I think you would be safest if you did it that way.
You will run two wires in the conduit, one is the hot, the other is the negative or wire attached to the white "ground" wire from the battery and tow vehicle. It does not matter which wire attaches to which on the brake magnet side. Use crimped connections, with heat shrink tubing for insulation where you splice it, and connect to the magnets.
