Old 07-25-2014, 02:54 PM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Wire to break away switch
The wire to my brake controller has frayed and separated. So I was wondering what would be the best way to replace it. As always I greatly appreciate any assistance.
John
urnmor is offline   Reply With Quote
Old 07-25-2014, 03:25 PM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Two terms: Break-away Switch and Controller..... 2 different things. Which do you mean? Your brake controller is in your tow vehicle and is wired through the umbilical. Your Break-away Switch is located on the trailer tongue. Can you post a pic of the problem?
arktos55343 is offline   Reply With Quote
Old 07-25-2014, 06:58 PM   #3
urnmor's Avatar
Berlin , Maryland
I cam unable to pst a picture however it is the wire to the breakaway switch on the trailer that frayed and separated
Old 07-29-2014, 10:28 AM   #4
2007 19' International CCD
The Woodlands , Texas
I also have the same problem with a frayed cable to the switch on the trailer tongue. I know you can buy a replacement cable and pin at most RV parts places, but I was never really clear on how this cable should best be run to minimize damage and optimize safety should a break-away occur? Any help would be appreciated.
eberrobw is offline   Reply With Quote
Old 07-29-2014, 10:53 AM   #5
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
The breakaway switch is very inexpensive, best to replace the entire switch, its only two bolts and two wires. The new switch comes with a new cable. I bought one from Vintage Trailer Supply.
There's lots of opinions on the correct way to route and connect the breakaway wire. Here's mine:
The breakaway switch is intended to activate the trailer brakes if the trailer separates from the tow vehicle. If the trailer is still attached in any way to the truck (ie. safety chains) you can still control trailer brakes with the brake controller. If the Trailer totally separates from the Truck you want those brakes on!
So you want enough slack in the cable that the pin doesn't pull out in a turn, but not so much that it can drag on the ground or get tangled in the hitch, safety chains etc. You also want the cable attached to part of the tow vehicle that is not part of the hitch.
I route my cable through the pad lock on the trailer coupler and attach it to an eye bolt I installed to replace one of the licence plate bolts (read that on the internet somewhere ) This way if the entire hitch falls off the truck, or the hitch head breaks and the safety chains fail, the pin will be pulled. My cable is long so I put a 6" loop in the cable and secured it with a small plastic zip tie. This way in a tight turn if the cable binds it can pull the loop out and not pull the pin.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is online now   Reply With Quote
Old 07-30-2014, 09:21 AM   #6
Thanks so much for the insight. The solution I thought I'd try is a product called Zip Breakaway Cable and Pin (6 feet).
The product is described as follows: At last, a breakaway cable that won't drag! If you are tired of frayed and broken breakaway cables, the Fastway® Zip™ is a must for you. The coiled cable keeps itself off the ground and out of harm's way while towing. Connects and removes quickly and easily with included carabiner. Available in 4' and 6' lengths, with or without switch.
We'll see how this works
Old 07-30-2014, 01:04 PM   #7
mefly2's Avatar
2015 25' FB Eddie Bauer
We have the Fastway now installed and the original one removed from a new AS two weeks ago. PM me your address and I will send it to you.
Old 08-02-2014, 08:03 AM   #8
Thanks but I also just installed the Fastway cable. I think it will be a good solution.
Have a great day.
Break-away switch recommendation? transy416 Hitches, Couplers & Balls 15 11-22-2009 07:36 AM
Testing Break Away Switch Sundance Brakes & Brake Controllers 11 11-15-2007 04:02 PM
Break Away Switch and Lanyard Question RBolton Brakes & Brake Controllers 6 01-10-2007 02:10 PM
Break Away Wire Damaged kposey Brakes & Brake Controllers 5 11-11-2004 07:20 PM
Break Away Brake Switch davespann Brakes & Brake Controllers 1 07-30-2003 08:22 PM
