05-03-2011, 09:26 PM
#21
2007 23' International CCD
Lapeer
, Michigan
Thanks. Looks pretty nice. What size do the Airstream wheels take? Does the padlock save the rotochoks or the Airstream or both?
05-03-2011, 09:43 PM
#22
Hollis
, New Hampshire
Neither! It just slows the thief down!
10-01-2011, 09:19 PM
#23
Port Orchard
Any updates to this thread? I am thinking about getting this type of device.
Splitrock, what did you end up getting?
Ken
10-01-2011, 09:57 PM
#24
Mini Rivet
1975 25' Tradewind
Holland
, Michigan
I have these, 10 seconds to put on and take off.
I have seen them advertised in the classifieds, I believe one of the forums members makes them.
10-01-2011, 10:10 PM
#25
Port Orchard
I remembered seeing those in the classifieds in the past, but can't find the now. I bought a high and a low aluminum jack stand from that gentleman. I have been pleased with them.
Ken
10-01-2011, 11:01 PM
#26
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
I have a pair of big yellow plastic wedges that draw tight via a screw mechanism. I found them at camping world and use the both every time I park, even if it is level.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
10-01-2011, 11:14 PM
#27
1978 28' Ambassador
Morada
This is the one we use...they work very well! - I forgot and left one in place when moving our AS - when I felt the resistance I knew right away I'd forgotten something!
Amazon.com: BAL 28005 Deluxe Tire Chock: Automotive
Easy to deploy and remove - it comes with it's own ratcheting socket/end wrench - and they are lockable to slow someone down a bit if they are trying to hitch up and steal your rig...
Ray & Pat; Morada, CA
10-02-2011, 06:13 AM
#28
2005 30' Classic
Burlington
, Ontario
I use similar chocks that I bought from Hensley when we got our hitch.
The only concern I have with them is whether they can apply enough force to actually put an axle out of alignment so I don't wind them up really tight. After all, they are essentially an automotive scissors jack used sideways.
Not sure if my concern has any merit or not!
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
10-02-2011, 07:50 AM
#29
1993 34' Excella
Estancia
, New Mexico
The wheelchocks shown on post 24 above can be found through ebay search "Airstream". These are the same or similar to the vintage chocks used in the 70s. It is a family business. If you don't see the chocks you probably will see a cast aluminum sewer hose holder. It is the same person. There are 2 sizes. The bigger one fit my 71 and 73.
10-02-2011, 08:01 AM
#30
1995 25' Excella
waynesboro
, Virginia
I use one and also yellow plastic wheel chocks
10-02-2011, 08:34 AM
#31
1986 32' Excella
Canton
, Georgia
We use two of the bal variety which use the racheting wrench.... But our airstream came with one of those aluminum ones, we have no idea how to use it! How do we find instructions?
10-02-2011, 09:43 AM
#32
Port Orchard
Brian
Thinking of the all the forces that a wheel and axle are subject to while sitting, let alone starting, stopping, and turning, it doesn't seem to me that it would be a concern.
Since the object is just to keep the wheels from rotating, I would not think that much force would be required.
Ken
10-02-2011, 08:07 PM
#33
2011 30' Classic
Kingwood
I have a pair of Roto Chocks and have been very happy with them. Easy to use, well built and seem to make the trailer more stable. Also if you have a Pro Pride or Hensley hitch it seems easier to hitch up with the chocks in place.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
10-02-2011, 08:47 PM
#34
Port Orchard
I don't understand the easy hitching part. It seems to me that with the chocks in place, I wouldn't be able to pick the tongue up and move it to where my wife is backing the truck.
Ken
10-02-2011, 11:34 PM
#35
1993 34' Excella
Estancia
, New Mexico
I once had a trailer start rolling when I took out the chocks before hitched. Now I hitch first. I don't care what kind of hitch.
10-03-2011, 05:28 AM
#36
2005 30' Classic
Burlington
, Ontario
Ken
Hi Ken,
You are probably right - but when I first got my Hensley, I was having some trouble at times getting it hitched up and got in the habit of banging quite hard back into the trailer to hook up. I was inclined to do that when I read in the Hensley manual not to be afraid to do so! (I have since learned that if you take the time to line things up well and use a couple of "aids" to lining up, there is no need for excessive force.)
When I was doing that, I cranked those scissor jack chocks of quite hard to ensure the trailer would stay put - that was when it occurred to me that by their nature, those jacks were likely capable of generating considerable force and I should be careful with them.
I don't "reef" them up so much any more!
Brian.
2005 Classic 30'
10-03-2011, 05:35 AM
#37
Corpus Christi
Same ones we have bmklawt. Came with the trailer when we bought it. I love them. Easy on and off, adjustable, no tools needed and the handle stays attached but when you release them they make a pretty small package that drops right into the bed of the truck. I use them all the time. Level site or not, they just add great stability and peace of mind when raising the front jack.
Guess it is just a personal choice, couple of 4 x 4's, cut to length, will also work.
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
10-03-2011, 06:30 AM
#38
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Bal's
Have used them since the first day with the Classic.....both sides.
Very secure...as you can tell, on a pretty steep angle in this pic.
10-03-2011, 01:20 PM
#39
Montreal
, Quebec
If you're looking for the nice aluminum wheel chocks; check out this photo.
I purchased 2 of them from the manufacturer.
She was real easy to deal with. Her name is Deb and you can email her at parttimerunner1@aol.com.
Ron
Montreal, QC
2017 Classic
4 Flexible 100w Solar Panels
3000w Magnum Hybrid Inverter
1000 Amp Hours Lithium Battery
Honda EU3000
Drain Master Sewer Connection
2017 GMC Denali 2500 Duramax
Hensley
10-03-2011, 02:18 PM
#40
WBCCI 8562
1975 31' Sovereign
Pelzer
, South Carolina
I use them, and have seen two episode recently of folks not using them. Brand new Airstream Classic, unhooks on a not level pad, trailer drops and rolls into his truck bending his electric jack..then another fairly new Airstream, unhooked, wheel chocks, gust of wind, it rolled bent his leveling jacks badly. I have used these since I had a trailer drop off the ball and jack went on my foot, 4 broken toes. Was not a big trailer either.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
NEW: 5th Wheel Airstream
Airtrekker |
Boondocking |
43 |
05-30-2020 09:11 AM |
wheel for 67
eubank |
Wheels, Hubs & Bearings |
5 |
03-06-2011 03:39 PM |
