Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 11-17-2008, 05:10 PM   #1
jm2
Learning....
jm2's Avatar
Profile:  2002 25' Safari
1981 31' Excella II
closter , new jersey
Which Brake Controller
Hi,
Am about to pull an '80 AS from eastern NY state out to Cape Cod, and looking for any suggestion for a suitable Brake Controller.
We're driving an '08 F150 Lariat SC. Thanks in advance for your help!
- JMJM
jm2 is online now   Reply With Quote
Old 11-17-2008, 05:19 PM   #2
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 65
Airstream Registry
Tekonsha makes the Prodigy and now the P3 controllers. They have cables for most trucks which makes the installation very easy. They are the most popular ones on the market. I have a Prodigy and it works very well for me.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 11-17-2008, 06:13 PM   #3
mustang's Avatar
Profile:  1986 31' Sovereign
Kent , Ohio
I have used, Draw Tite. It is very affordable and reliable.
There are many brake controlers, all are good. I would advice staying away from the pendulum or inertia controlers myself.
Didnt Ford install one with there tow package??
mustang is offline   Reply With Quote
Old 11-17-2008, 06:27 PM   #4
Profile:  2008 25' Safari FB SE
Crawford , Colorado
Check with a Ford dealer for the brake controller option since you obviously don't have one installed (if you do, please see an eye doctor immediately) since I think it goes on the dashboard and you could actually see it when you are driving. I have a Prodigy and it works fine, but had to be installed at the bottom of the dash where it is hard to monitor and if you have to use the manual control in an emergency, you probably can't without losing steering control.
Gene
CrawfordGene is online now   Reply With Quote
Old 11-17-2008, 06:29 PM   #5
Profile:  2005 28' International CCD
West Palm Beach , Florida
I recently purchased the Hensley Brake Controller. I believe it is called the "True Control". It is a little more money but like the Hensley Arrow, I think it is excellent quality. The nice thing about Hensley is they have great customer service and work closely with do-it-yourselfer's.
John Geisen
John Geisen is offline   Reply With Quote
Old 11-17-2008, 06:34 PM   #6
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
We have two TV's one with the Prodigy and the other with the P3. The P3 is the best.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 11-17-2008, 09:25 PM   #7
Profile:  1973 31' Excella 500
Morristown , Tennessee
I have a 2005 GMC Denali PU. I bought the Prodigy unit online and it was a plug and play deal with the truck prewired for a brake controller. Attached it to the lower dash where I can adjust while on the move. Did the whole thing in the previous owner's driveway, attached the umbilical cord, checked lights and brakes and drove home. Haven't had a problem since 2006. Good luck.
Joe DeFelice
1973 Excella 500
Alumin8 is offline   Reply With Quote
Old 11-17-2008, 10:41 PM   #8
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
Airstream Registry
Hi, to the best of my memory F-150's don't have the brake controller option. So I would recommend a Tekonsha P-3. And you can be creative on mounting locations in some vehicles. I had my Airstream dealer install the Tekonsha Voyager in this little pocket area instead of under the dash. Later I replaced the Voyager with the P-3. I don't have the best view of the unit while driving, but it is very easy to find if I ever need to manually hit the trailer brakes. Click on picture for a larger view.
Name:	San Clemente 2008 001 (Large).jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 11-18-2008, 06:24 AM   #9
jm2
Learning....
jm2's Avatar
1981 31' Excella II
Brake Controller
Thanks to all for your input.
The '08 F150 offers only the "trailer towing package" that does not include the brake controller. But they do give you a handy little plug-in harness to connect your controller with.
- JMJM
Old 11-18-2008, 08:27 AM   #10
reggiemon's Avatar
Profile:  1959 18' "Footer"
Corpus Christi , Texas
Hi, I dont mean to hijack the thread but are there any others out there with brake controller mounting suggestions/pictures. I am mounting one in a Montero and if I mount it under the dash, you cant see it or get to it easy. Thanks!
1959 "Globester"
reggiemon is offline   Reply With Quote
Old 11-18-2008, 09:37 AM   #11
BWH-Utah's Avatar
Profile:  1965 22' Safari
Salt Lake City , Utah
I use a Prodigy by Tekonsha with my 2006 Ford Explorer and 1965 Safari (22foot). Get the Ford wiring harness (~$13) and instillation is very easy. Just plug one end of the harness into the trailer brake connector under the dash of your Ford, and the other end of the harness plugs into the brake controller. At that point all electrical wiring for the brake controller is done. On my first trip I mounted the Prodigy to the top of the dash with duct tape (not recommended, but it worked very well), I now have it screwed to the dash, left side of the steering column. It brake controller is inertial (sences how much the tow vehical is slowing down) so you want it securly mounted.
The only other wering to check is the trailer connector to the back of the TV (7-prong connectors are the most common).
Happy towing, BWH
BWH-Utah is offline   Reply With Quote
Old 11-18-2008, 11:46 AM   #12
"CLOUDSPLITTER"
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
Airstream Registry
Thumbs up TruControl
John Geisen
John, I'm with you on this one. Got the TruControl when I got the HAHA.
I've used a number of different BC's over the years and this has been the best hands down.
just MY opinion.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Brake controller? chaunceyboy Brakes & Brake Controllers 7 06-07-2007 10:43 PM
Brake Controller sstjacque Brakes & Brake Controllers 24 11-01-2005 07:19 AM
Brake controller Theo Brakes & Brake Controllers 21 01-30-2004 09:43 AM
Brake Controller (which one ) poorboycjs Brakes & Brake Controllers 3 07-25-2003 05:42 AM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
