Old 12-16-2002, 04:33 PM   #1
Anna's Avatar
Where to buy brake shoes?
Hello,
Was wondering where we should buy brake shoes for our 1973 Overlander?
Anna
Anna is offline   Reply With Quote
Old 12-16-2002, 06:02 PM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Just about anywhere....
That sells Dexter axle parts, which are used on most TT's. Airstreams use Henschen axles or Dexters, with Dexter break plates. You can also order them from Andy at Inland RV, or Airstream themselves. Don't forget to check your magnets! They wear out quicker than the brake shoes.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 12-17-2002, 08:41 PM   #3
LLB21's Avatar
The brake shoes are not special for Airstreams. They can be purchased at any RV store. RV dealers order direct from RV parts distributors. Take one of your old ones with you to compare.
Louie
LLB21 is offline   Reply With Quote
Old 12-17-2002, 08:56 PM   #4
Chas's Avatar
Images: 22
Lightbulb
You can also check out companies that sell and service utility trailers. Sometimes just adding the word "recreational" to items needed on your A/S can quickly make the price double, even if it is a common part used in other products. Just like going to your marine dealer and buying belts and filters, you can get the same stuff at your corner parts house but much cheaper.
Chas
Former Airstreamer
Chas is offline   Reply With Quote
Old 12-18-2002, 03:55 AM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Talking Brakes
Anna,
I replaced 4 entire brake assembly last summer at the factory and, I remember the price was around 89$ each.
They just took off the old brake sys housing(my unit is an 84)and installed the new ones.
When you buy them this way, it comes complete with the new brakes and magnetic.
Labor cost is additional.(65$ per hour)
BTW, This is an excellent time to repack the wheel bearings as well.
ciao
(thanks Andy)<g>
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
New brake shoes and jacking point wayner1239 Brakes & Brake Controllers 6 04-23-2008 07:03 AM
Brake Seizure - Front Right Side josephhh Mechanics Corner - Engines, Transmission & More... 15 03-26-2004 10:15 AM
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 06:47 AM
Brake Horror Story Mike76251 Brakes & Brake Controllers 4 10-06-2003 11:41 AM
replacing brake shoes gjohnson Brakes & Brake Controllers 1 08-28-2002 01:03 PM
