Old 08-13-2004, 12:31 PM   #1
tinsltootsie's Avatar
wheel needed for 74 Overlander
I don't know if anyone has located a vendor for replacement wheels for a 74 overlander. We called Park and Inland, and neither have the wheels. The PO replaced with a wheel that never quite fit right. At this time my husband is taking care of the brakes, bearings, etc, but said the wheel is no good, and when we checked these two suppliers, they didn't have any. We are also working with our local trailer repair/salvage shop. So far, no luck! Any help would be appreciated.
tinsltootsie is offline   Reply With Quote
Old 08-13-2004, 05:29 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Try Colaw's RV Salvege, they are parting out many Airstream trailers.
Also, a search for "trailer wheels" might bring more options.
The wheel size should be 15x6, offset "0"
Uwe
www.area63productions.com
Old 08-18-2004, 07:40 PM   #3
Thanks. I will check it out. We are still stalled on the wheel. I will pass on info recieved to my husband. He understands this stuff. Thanks again.
Old 08-18-2004, 09:24 PM   #4
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
RV Salvage yards
Used RV wheel should fit the bill.
Here's a link. - http://www.ccis.com/home/mnemeth/rvsalvage.htm
There is a yard in Lebanon PA that may help.
>>>>>>>>>Action
Old 08-18-2004, 10:28 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
Greetings Debbie Noon!
If what you are seeking is a standard trailer type steel wheel, your Good Year dealer may be able to source a wheel for you. My local dealer was able to source trailer rated wheels with 2,600 pound capacity for my '64 Overlander through one of his regular sources (in '98, they were $49 each) - - they were a special order from a catalog and took about 72 hours for delivery. The Good Year dealer that I usually patronize is in a rural area and services semis, farm implements, trucks and passenger cars as well as RVs of all types.
Good luck with your search!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
Old 08-27-2004, 08:22 PM   #6
THanks for the info. We were able to get a new wheel from Delaware and also got a used one from Colaws. So we even have a spare! But for a while there it looked pretty bleak. The PO had a wheel on that didn't fit well and messed up some things. Right now we are looking pretty good.
Kevin
Wheel Bearings for a '74 Overlander AV8 Axles 5 02-03-2004 10:42 AM
Wheels for 1961 Overlander David Hall Wheels, Hubs & Bearings 19 01-29-2004 07:24 AM
Battery for 76 Overlander needed tin can luv General Interior Topics 2 01-19-2004 08:20 PM
