Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 10-06-2003, 07:16 PM   #1
erstrong
Profile:
Angry Wheel lockup
After turning onto the gravel road which led to the campground, the left wheel locked up. Backed up, did no good. Unplugged the connector, no help. Finally dragged it to the CG which was less that a quarter mile down the road. Put a heck of a furrow in the road.
Repair person found the whole wheel to be tight - couldn't turn it. He went to the breakaway switch, wiggled it and the wheel freed up. Both shoes were loose and the adjuster was in several pieces. Springs were broken. The tire was ruined.
No agreement that the breakaway switch was at fault. If it was the problem, why did it affect only the one side? Local AS dealer hasn't a clue. Any ideas? Could broken springs have been the cause?
New shoes, adjuster, and springs made it good as new. Will have the other side checked this week.
erstrong is offline   Reply With Quote
Old 10-06-2003, 08:44 PM   #2
j54mark
Profile:
A spring or the adjuster failed. It is recommended that all brake parts be replaced, as a regular maintanence item, every 39 years.
Mark
Old 10-07-2003, 12:52 AM   #3
JodynJeep
JodynJeep's Avatar
Profile:
Images: 57
May also want to check your brake controller settings. I have experienced issues where a wheel would lock up - and it was because there was too much tension being dialed in from the brake controller in the cab (and or plug not securely pushed in)....
Jody - Jody's Website
JodynJeep is offline   Reply With Quote
**Broken Wheel Well** Silvertwinky Wheel Wells 8 05-26-2006 02:57 PM
Wheel Chocks pjtaia On The Road... 13 10-28-2005 02:27 PM
'66 Tradewind wheel bearing size? dreamqueen 1959-69 Tradewind 1 02-18-2004 06:13 PM
need to replace the wheel...are there jacking points? 60traveler Towing, Tow Vehicles & Hitches 1 06-25-2003 03:05 PM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
