Old 10-19-2018, 03:40 PM   #1
2017 19' Flying Cloud
Warrenton , Virginia
What type brakes do I have?
I am buying a 2017 19' Flying Cloud and will be towing it with a Toyota Tundra which has a built-in brake controller. My Tundra instruction manual requires that I set up the controller for either electric brakes or electric over hydraulic brakes. Can someone tell me which is on the Flying Cloud?
Thank you.
Chris Borth is offline   Reply With Quote
Old 10-19-2018, 03:55 PM   #2
2018 28' International
Fayetteville , Georgia
If your brakes are original they are electric actuated drum brakes. If they were changed (unlikely) to disc brakes, they would be electric over hydraulic.
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 10-19-2018, 05:29 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 36
Just Take a Quick Look
If you have electrically-activated Hydraulic brakes you will find the master cylinder mounted on the tongue of your Airstream behind the propane tanks, perhaps inside a grey colored steel box.
Or, Look at the wheels and you can determine if you have drum brakes (Electric)
or disk brakes (Hydraulic)
Ken L
1966 Tradewind 24
2018 GMC Yukon XL Denali
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 10-19-2018, 06:14 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
If a 2017 has disc brakes, there won't be any equipment located on the outside of the trailer like from years ago. There will be a small brake actuator, which is a pump, hidden somewhere inside the Airstream. Chances are you have the magnetic type drum brakes.
Old 10-19-2018, 06:22 PM   #5
Long Island , New York
Welcome to the forum, Chris! Your owner’s manual would be a good place to start. Also the private seller or dealer should be able to help. You probably have electric actuated brakes IMO.
Good luck,
Peter
Old 10-19-2018, 07:26 PM   #6
Wrangler's Avatar
2019 19' Flying Cloud
Renville , Minnesota
My 19’ came with drum (electric) brakes. I suspect that is what came from the factory in 2017.
I currently camp in a 19’ Flying Cloud towed by a Nissan Frontier.
Wrangler is offline   Reply With Quote
Old 10-20-2018, 08:54 AM   #7
The lady I am buying from said she has not done anything since she bought it new so that means it is electric based on your responses. Thanks all.
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 11:18 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 06:56 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 05:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 08:20 PM
