Old 04-19-2010, 11:49 AM   #1
1970 31' Sovereign
danville , California
what sized wiring for brakes?
I am replacing all the wiring on a 58 jewel, I know the running, and brakes lights will be run in 14 guage, I am just wondering what size should I run the electric brakes in. I think 14g is a little on the light side and as you all know wire isnt cheap so I want to make sure I get it right the first time.
gmwelder86 is offline   Reply With Quote
Old 04-19-2010, 01:05 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Here's one recommendation from Dexter:
http://i.b5z.net/i/u/1080235/f/Brake...agram_6-09.pdf
Old 04-19-2010, 01:08 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
!2 stranded should be adequate. Standard practice is to run both leads to the brakes, hot and ground instead of picking up ground from the trailer frame.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-19-2010, 02:00 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes #12 is the min. Another consideration is the size in the TV. I run a separate # 10 wire from the brake controller to the rear of the TV. Voltage loss over the length of the wire is the reason. Many manufactures use #14 wire in the factory wiring and this is inadequate.
2004 Excursion 4x4
Old 04-20-2010, 10:34 AM   #5
1970 31' Sovereign
Thanks, I am thinking seperate dual #10 from the harness connection to each brake.
Help on wiring brakes please! UK novice in trouble John B Keith Electrical - Systems, Generators, Batteries & Solar 11 08-26-2008 12:30 AM
1969 Brakes need wiring info CJ of Okla Brakes & Brake Controllers 10 07-21-2008 05:55 AM
Wiring a dolly with electric brakes noiva Mechanics Corner - Engines, Transmission & More... 4 02-14-2006 06:47 PM
Wiring Electric Brakes buckeye Brakes & Brake Controllers 2 07-21-2005 08:35 AM
Wiring brakes Cruiser Brakes & Brake Controllers 7 05-24-2005 06:13 PM
