Old 02-09-2009, 08:03 AM   #1
coffeydelsol's Avatar
1986 25' Sovereign
Ocala , Florida
What size brakes?
Does anyone know what size brakes are on a 1986 SOV 25' unit? My partner had pulled the wheels and repacked the bearings and checked everything. He felt that the brakes were really worn and after a 2 day search for a "c" clip, we have decided to replace the the brakes. We are going to call around for some quotes, but need to know the size. Thanks!
coffeydelsol is offline   Reply With Quote
Old 02-09-2009, 08:28 AM   #2
Should be 12 inch.
Either measure inside of the drum, or, look at the plate that the brakes are mounted to.
If it's square, with 4 holes, then you have 10 inch brakes.
If it's round, with 5 holes, then you have 12 inch brakes.
Old 02-09-2009, 06:36 PM   #3
1986 25' Sovereign
Ocala , Florida
They appear to be 10'' is there a 10'' backing plate available? Do i have to up grade to a 12'' backing plate and new drums? If so do i have to replace my rims also?
Old 02-09-2009, 06:41 PM   #4
1986 25' Sovereign
Ocala , Florida
10'' brakes
I have a 86 sovereign w/ 10'' brakes does anyone know if 10'' backing plates are available? If not when i go to 12'' brakes I have to replace my drums also, but do I have to replace my rims too?
Old 02-09-2009, 06:52 PM   #5
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Sure - here you go.
Trailer Parts Superstore - Brake Drum & Hub Assemblies
Scroll down to the 10" Dexter with 6x5.5 bolt pattern.
Interesting that after all the talk about 10" brakes, that AS used them for such a big heavy trailer as recent as '86.
Why replace the drums? Do you really need 12" brakes? Is it not working well as is?
No, the wheels will work as is.. as long as you do have a 6 bolt hub.
Marc
Old 02-09-2009, 07:09 PM   #6
1986 25' Sovereign
Ocala , Florida
There shot. Magnets are down into the coils and drums are gouged pretty bad. i just bought the trailer and it doesnt look like the previos owner paid much attention to them.
Old 02-10-2009, 06:22 AM   #7
1986 25' Sovereign
Ocala , Florida
thanks for your help!!
Old 02-10-2009, 08:38 AM   #8
If the brakes and hub and drums are shot, you might do well to check out the axles as well.
It costs less to replace a complete axle, than it does piece by piece.
Old 02-10-2009, 08:46 AM   #9
1975 Argosy 26
1963 24' Tradewind
If you're drums are ok, then I'd just replace the backing plates... and use the trailer as is. I'm sure your axles may have settled a bit, but if you're pressed for money, you can do it in pieces. It's easy to order an axle "bare", and then put your newer brakes on it from there too.
I say enjoy it for awhile first.
Marc
Old 02-10-2009, 09:10 AM   #10
You can upgrade the brakes to 12 inch, should you decide to replace the axles.
That would give you several thousands of pounds of extra stopping power.
Old 09-16-2009, 05:34 AM   #11
Ottawa , ON
Originally Posted by 3Ms75Argosy View Post
Sure - here you go.
Marc
Marc,
That link goes to hydraulic brakes only.
There is a link on the site for electirc RV brakes, though: Trailer Parts Superstore - Electric Trailer Brake Assemblies
Or, click here if the link wraps and won't work.
Biggest model of 10" brakes only has a 3,500 lbs per pair load rating. Does that sound right?
brakes KeithC Brakes & Brake Controllers 8 09-21-2007 10:00 PM
Brakes help rebel beck Brakes & Brake Controllers 3 07-18-2006 05:26 PM
Brakes Or No Brakes 62safari Brakes & Brake Controllers 3 01-24-2006 09:18 AM
No Brakes IndyCutter Mechanics Corner - Engines, Transmission & More... 6 01-21-2006 06:43 AM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
