Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 08-19-2010, 02:37 PM   #1
Santa Fe , New Mexico
what kind of brake tool do I need?
I want to adjust the brake shoes on my 2006 Safari for the first time. Can anyone recommend the best type brake adjuster lever to use? Or will a screwdriver work just as well? I saw 2-3 different types of levers at Pep Boys and had no reason to pick any of them.
mistermcfrug is offline   Reply With Quote
Old 08-19-2010, 02:49 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The standard tool with a 45 degree spoon on one end and a straight spppon on the other should work just fine.
If you have self adjusting brakes you should not have to adjust them. Now that said if you do have to adjust them after replacement or for some othe reason you will have to slip a small screwdriver in to push the adjuster off the star wheel.
In some systems you will have to slip a small screwdriver in to lift the spring off the star wheel. You should be able to see what you are up against with a flashlight and looking in through the adjuster hole.
2004 Excursion 4x4
Old 08-19-2010, 02:56 PM   #3
Splitrock's Avatar
Sioux Falls , South Dakota
My brake adjuster has two different end angles. I used the milder of the two on my Airstream. I set up the brakes on my tandem flatbed trailer this week and used the sharper angled end on that. I like having one of about everything in my tool box.
Old 08-19-2010, 05:38 PM   #4
1972 Travelux Princess 25
Cobourg , Ontario
If the adjuster is like a drum brake car you can turn the wheel to tighten the brakes easily but if you want to back them off you have to push the self adjuster away.
I like to adjust them slowly while turning the wheel and stop as soon as I hear a slight drag.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 08-20-2010, 10:48 AM   #5
Thanks!
I appreciate the time the above posters spent helping me!
Old 08-20-2010, 01:08 PM   #6
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I think that the simple answer is that you can use a screwdriver for the adjusting, but depending upon space, angles, etc., the brake adjuster tool, being wider than most screwdrivers and having several possible angles (dpending upon which way it's deployed) will save some aggravation and perhaps a few skinned knuckles.
AirsDream is offline   Reply With Quote
Old 08-20-2010, 01:48 PM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Auto Zone shows the brake adjuster tool on their web site for $4.99. Worth the money! AirsDream is correct and you can do it with a screwdriver, but it is MUCH easier with the tool.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-20-2010, 02:00 PM   #8
Kevin245's Avatar
Ditto on the adjustment tool. It will lay around in your toolbox 99.9% of the time but when you need it...Your task will be much easier with it as opposed to a screwdriver. I keep mine with another seldom used tool...A distributor wrench.
Kevin
William C. Swinney
Old 08-20-2010, 02:16 PM   #9
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
They also make a good mini pry bar.
Vaughan
Old 08-20-2010, 03:42 PM   #10
AirsDream's Avatar
1999 23' Safari
Oh yeah, a distributor wrench. That and a timing light and a basin wrench and a valve spring compressor and cleco pliers are those sorts of tools you hardly ever need, but when you need 'em, you really need 'em bad. You really can (usually) use a screwdriver on drum brakes, but there's not much substitute for some other things.
Old 08-20-2010, 04:36 PM   #11
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
If you haven't done it before then one thing I would suggest is to pull one brake drum off and they you wil see exactly what you are dealing with and what tool will work best for you.
A screwdriver may work fine - but a generic brake adjusting tool should only be a couple of bucks.
Brian
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
What's this tool? SafeHarbor Off Topic Forum 71 05-30-2012 08:06 PM
Best polishing tool joe77 Cleaning, Stripping & Polishing 27 05-05-2010 05:16 PM
Great Tool Up A Stream Member Introductions 6 09-07-2009 02:09 PM
Best rivet tool? Andy R Ribs, Skins & Rivets 9 09-24-2006 07:36 AM
New kind of brake controller 71tradewind Brakes & Brake Controllers 6 10-18-2003 04:34 PM
