Old 10-13-2019, 04:31 PM   #1
2000 31' Excella
Ontario , Canada
What is function of brown wire on Actibrake
It seems as though I have my Actibrake wired incorrectly on my 2006 classic 31. The black 10g 12V hotwire from the TV is supposed to be wired directly to the Actibrake and not to the 12V positive buss bar and then to the Actibrake. But trailer batteries still need a charge from TV to maintain trailer batteries. The wiring diagram shows the brown wire from the Actibrake connected to the trailer battery. But the wire size seems to be 16g. Is this too small to maintain charge in trailer batteries????? What other use could this brown wire be performing?? Can you hook up a 10g black wire from the 12v wire going into the Actibrake but restrict current so that it only goes one way ie: into the trailer battery but not allow charge from trailer battery to get to the Actibrake????
Woody
woodytwo is offline   Reply With Quote
Old 10-13-2019, 05:11 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Why not leave everything else as it is, and run a dedicated wire from the batteries to the brake actuator?
Brown/Gray and white wire pair stuffed into floor gklott Electrical - Systems, Generators, Batteries & Solar 3 07-20-2017 05:03 PM
brown and green wire? spanky1313 Refrigerators 6 05-14-2008 06:02 AM
Setup of Actibrake with Kodiak disks on Bambi mswartz Brakes & Brake Controllers 18 02-13-2007 11:31 AM
sens-a-brake vs actibrake ljmiii Brakes & Brake Controllers 4 01-29-2007 07:56 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
