Old 01-15-2007, 07:15 AM   #1
2007 25' Classic
marco island , Florida
voyager brake controller
i just spoke with active brake and their electric/hydraulic brake system WILL NOT work with a voyager controller. the only controller approved with the elec/hydraulic system is the prodigy....so the dealer is changing it out.
van
vpurdy is offline   Reply With Quote
Old 01-15-2007, 07:18 AM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
It's for the best....even with non disc brakes, the Voyager gave me nothing but problems and did a poor job controlling the brakes....they'd lock, grab, etc. Prodigy is as smooth as silk (at least with my electric drums).
I don't think you'll be disappointed.
Old 01-15-2007, 07:29 AM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
That is in direct conflict with thier own technical bulletin.
Whats up with that?
Michelle TAC MT-0
Sarah, Snowball
Old 01-15-2007, 10:29 AM   #4
2007 25' Classic
active
i don't know what's up...if you read the teconsah web site it says none of their controllers have been tested with elec/hyd system and you should contact the brake mfg directly...i did and they said they have tested extensively on the prodigy and loaded new software etc to make it work with elec/hyd....but NOT the voyager...only the prodigy. i spoke with Mike at active brake directly....go figure. van
Jordan Research Ultima Brake Controller RoadKingMoe On The Road... 0 09-26-2002 12:41 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
Ok, I need a brake controller Chuck Brakes & Brake Controllers 6 06-07-2002 12:43 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
