Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 08-25-2002, 09:12 AM   #1
Coastalview
Coastalview's Avatar
Profile:  1978 29' Ambassador
Carmel , California
Post Vacuum source for hydraulic brakes
Hi everyone!,this being my first post,I hope this info could be of use. I recently purchased a 1978 28 ft. Airstream with the hydraulic brake system. At first glance,I realized that the system seemed to be fairly complex,looked like something from the 50's and wasn't sure of its operation. My first consideration was my ability to tow it without the vacuum connection for the brake system,and towing it with my diesel pickup. These two concerns weighed in my thoughts as I pulled away with this new purchase in tow,with a six hundred mile return trip home. My first consideration that my truck could handle the additional weight, if I drove conseravitively,second thought was my trucks ability to supply vacuum to the trailer brake system. My truck has a mechanical vacuum pump driven by the engine, and at best, this pump does a good job of keeping up with the demand that it serves, but didn't believe that any additional vacuum load would be a good idea. Searching the web, I discovered a few inovations resulting from others with vacuum problems. I'm currently using a used vacuum pump from General Motors car, that I installed adjacent to the vacuum braking unit between the trailer frame rails. To this day, I have had no trouble with its ability to supply vacuum under braking conditions and the unit is automatic. I had considered the replacement unit that Andy at Inland RV. has availible, but my better half has a tight restriction on any funding this new project. Thanks inadvance for any replies,Jeff
Coastalview is offline   Reply With Quote
Old 08-25-2002, 10:09 AM   #2
mkeith54
mkeith54's Avatar
Profile:  1976 26' Argosy 26
New Florence , Missouri
Vacuum source for brakes
I think that i'd consider changeing over to electric brakes. In the long run I think that you'd be happier. If I recall right you can get new backing plates with all the parts installed and just swap them, you'd have to run new wiring to the brakes and add a controller.
Mike
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
WBCCI 4503
Gr8r STL Unit
mkeith54 is offline   Reply With Quote
Old 08-25-2002, 10:51 AM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Jeff. Electric brakes will never duplicate the job that the disc brakes offer.
Having a separate vacuum pump is OK, but if you pump the brakes, you will loose all the vacuum.
Secondly, towing without brakes, creates a liability should you ever hit someone. With as many foolish drivers that are on the highways today, should any one of the slam on their brakes or cut in front of you, you will never slow down in time, to avoid an accident. Any guard house attorney will take you to task for operating a travel trailer on a public highway unsafely. Your liability carrier will cringe at the thought.
Changing from the disc brakes to electric brakes costs far more that the "braker."
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 08-25-2002, 10:54 AM   #4
mkeith54
mkeith54's Avatar
Disc Brakes
Andy,
What about going to electric disc brakes? Seems to me then you have the best of both worlds.
Mike
Mike Keith
75 Argosy 26'
WBCCI 4503
Gr8r STL Unit
Old 08-25-2002, 12:39 PM   #5
Commercial Vendor
Mike. That's what the "braker" does. It replaces the entire booster assembly that you now have, is electrically driven, and retains all of the hydraulic portion of the disc's.
Additionally the braker costs less overall than changing to the all electrics.
inlandrv.com
airstreamparts.com
Inlandrv.com
800-8777311
Old 08-25-2002, 01:34 PM   #6
Coastalview
Carmel , California
Thanks for the fast responses, I"m working with fianance to allow me to buy the breaker unit from Andy at Inland RV. The principles of the the way I've corrected my delimia suits my needs,but as Andy mentioned, DOT may frown on my system of design,and I may suffer acordingly, if I ever had an accident. Thanks again for each of your insights,I can't think of a better built travel trailer,( my new purchase was sitting for 12 years uncovered,with no leaks,and everything still fucntioning) Try leaving another brand of trailer out for that long,and see if even the a floor remains! Jeff
Old 08-26-2002, 09:20 AM   #7
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
Coastalview,
Andy has been right about the hydraulic/vacuum brakes. I have them on my '77 Excella 500 and they work great. I too listened to the comments from others about changing to electric brakes and received a price quote from the factory in Ohio of over $1000. You have a good system built into your trailer and the only modification I would make to it would be the "braker" system if an electric vacuum pump does not suit your needs. I've had my 31' trailer for over 15 months now and have put maybe 3000 miles on it since it's purchase. No problems with the brakes at all.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
vacuum brakes 1977 landyacht acme Brakes & Brake Controllers 35 04-24-2003 07:19 PM
Vacuum Disk Brakes APB Brakes & Brake Controllers 1 04-07-2003 11:14 AM
vacuum power disc brakes trumpwer Brakes & Brake Controllers 1 03-09-2003 12:08 PM
Vacuum Brakes suprtrker Brakes & Brake Controllers 2 11-29-2002 10:39 AM
Rotors for vacuum disk brakes wvmiller Brakes & Brake Controllers 4 10-21-2002 04:43 PM
