Old 04-26-2003, 07:26 AM   #1
Vacuum disks locking unexpectedly
After years of faithful service, I relined my disk brakes and install new rotors last fall. This week I pulled my 78 Excella out of storage and headed for the Ozarks. About an hour down the road, my brakes unexpectedly locked up, and pulled my tow vehicle to a crawl before I figured out what was wrong. I stopped, walked around, and could find nothing wrong except hot brakes. I started the truck up and head down the road for a half hour when the same thing happened.
Suspecting my brake controller (I'm not sure why) and being on mostly level ground, I disconnected the controller and again drove on. Half hour later, same thing, so the problem has to be in the brake actuator on the trailer.
The lock-up seems to occur after a period of downhill coasting (high vacuum), and is "cured" by simply pulling over and stopping. I replaced a cracked truck to the brake acuator hose (the truck hoses are fine), and reconnected the brake controller after checking it. That seem to improve things; but I still had a unexpected stop or two on the way home.
What should I fix? The breakaway valve? Vacuum reservoir? Hoses in the acuator (which look fine).
I'm hoping Andy at Inland or some other disk brake expret will see this and give me some ideas. I'd prefer not to tow that way again.
Bill & Jeanne Miller
78 Excella 31 CB
St. Louis
wvmiller is offline   Reply With Quote
Old 04-26-2003, 10:12 AM   #2
Bill.
Disc brakes can be actuated whenever there is a sudden loss of vacuum. You could perhaps have a bad "breakaway" switch.
You could also have a defective check valve in the vacuum line from your tow vehicle.
You could also have a defective brake controller or wiring related to it.
inlandrv.com
airstreamparts.com
airstreamcandy.com
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 9 07-12-2014 07:41 AM
Central Vacuum Cleaner Snadi Nu-Tone Appliances & Central Vac System 8 06-23-2005 06:29 AM
vacuum system ques? zduke4x General Motorhome Topics 5 03-14-2004 11:38 AM
vacuum brakes 1977 landyacht acme Brakes & Brake Controllers 35 04-24-2003 07:19 PM
Rotors for vacuum disk brakes wvmiller Brakes & Brake Controllers 4 10-21-2002 04:43 PM
