Old 04-08-2012, 08:32 AM   #1
1978 31' Excella 500
Riviera Beach , Florida
Vacuum brakes
I have recently purchased a 1978 31 Excella trailer with vaccum assisted brakes. My Ford F250 diesel doesn't offer much manifold vacuum, so I will need to add a suction/vacuum pump to power the brakes. Can anyone tell me about the required capacity for such a pump, or recommend a particular pump that has worked for them?
JOHNMARDALL is offline   Reply With Quote
Old 04-08-2012, 08:40 AM   #2
1960 24' Tradewind
Riverside , California
Couple of options for you, some diesels can have a cam driven vacuum pump installed.
You can install an electric over hydraulic pump to operate the disc, Carlisle makes a decent one, there are others
You can install a 12v Vacuum pump on the trailer, there is a vacuum storage tank under the floor, keep vacuum available for the system.
Convert to electric brakes and drums.
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 04-08-2012, 09:07 AM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
conversion to electric brakes
This is the route that I took. It is cheap and can be done in an afternoon.
Old 04-08-2012, 09:20 AM   #4
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Also if you convert to electric brakes your system will be compatible with almost anything you need to hook to. The old vacuum system is pretty much an orphan.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 04-08-2012, 09:21 AM   #5
Retired.
. , At Large
You can also convert to an electric actuator for your disc brakes. The Dexter actuators are available from Airstream. You can remove the booster and master cylinder, and all the vacuum hoses, and install the electric actuator in its place. It will work from the signal from the brake controller on your truck
Old 04-08-2012, 10:39 AM   #6
Using a vacuum pump, is a very bad idea.
In the past, when someone has done that, three applications of the brakes, totally uses all the vacuum, and then you have ZERO brakes.
Converting to electric brakes, is going backwards in the safety that your disc brakes offer.
An easy, but not entirely cheap fix, is to replace the actuator that's behind the LPG bottles, with a current style actuator. No vacuum needed and the disc brakes will work as good as ever.
Several owners have made that conversion, and they are all happy that they did.
Stay with the discs. Your family will be glad you did.
l
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-08-2012, 12:21 PM   #7
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I agree with what Andy said and did replace my vacuum/hydraulic actuator with a Carlisle 1600 electric/hydraulic unit installed behind the propane tanks. The original Ausco rotors I'm told are not available anymore but the brake pads are. Provided that your rotors and calipers are in good shape, you can get many more years of reliable service from them.
4RXLA is offline   Reply With Quote
Old 04-08-2012, 01:08 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
John
The other posters are correct that the vacuum system is obsolete and should be replaced with something else.
Current production Airstream trailers all ship with electric brakes. I would guess that the cheapest and most straightforward thing you could do would be to replace the existing brake system with electric backing plates and drums. You can check prices on etrailer.com but I'm guessing it will be around a $600 project all together.
If the calipers, lines, hoses, and rotors are in good condition you could also consider the electric actuators. There's the potential for better braking performance and less maintenance. On the other hand some members have run into a variety of difficult problems with controller compatibility, getting the brakes bled completely, and line failures due to abrasion from tires or suspension components.
Old 04-08-2012, 01:44 PM   #9
JFScheck's Avatar
2020 30' Classic
Derwood , Maryland
Images: 37
As of now (granted no mountain towing yet) - the disc on my 2009 25 footer and drums on my 30 footer feel and appear to work about the same....
So, maybe electric drums are not as bad as I feared they would be!?
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-08-2012, 02:25 PM   #10
Excella CM's Avatar
Venice , California
If you go with a vacuum pump you can add a vacuum tank to increase the system capacity. Also, if you do opt to scrap the system, put the parts up for grabs on the forum, they are hard to come by these days.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 04-08-2012, 02:29 PM   #11
That three times and the vacuum is gone, "IS" using the tank that came with the Airstream equipped disc brakes. Doubling the tank capacity, made very little difference.
Granted, maybe a 10 gasllon tank would work better, but where would you install it?
When it comes to brakes, GUESSING should never be in the formula. Facts and nothing more.
Also, disc brakes do not fade like electric brakes.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-08-2012, 02:38 PM   #12
2009 28' Flying Cloud
Canora , Saskatchewan
It seems that everyone is making the assumption that the brakes are Disc brakes,is this indeed true. It will depend on which brakes they are before a solution can be suggested.
MervM is offline   Reply With Quote
Old 04-08-2012, 02:47 PM   #13
The vacuum assisted brakes are indeed disc brakes.
They were basically standard on many of the Excella models.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-08-2012, 03:29 PM   #14
1965 22' Safari
East Islip , New York
True, but it's not the electric actuators that are the cause of the fading, it's the drum brakes.
-Hans
HHaase is offline   Reply With Quote
Old 04-08-2012, 09:45 PM   #15
-Hans
Correct.
Brake rotors do not share the same problems as brake dums experience from heat.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 04-09-2012, 07:52 AM   #16
Thanks everyone. The brakes are disk brakes. I think that I'll go the simplest route and replace the vacuum system with an electric actuator.
John Mardall
Old 09-17-2012, 10:38 AM   #17
1980 31' Excella II
Springtown , Texas
John,
Which actuator did you go with and how was the install?
Ritchie Tice
RTice is offline   Reply With Quote
Old 08-05-2015, 07:33 PM   #18
Bonnyville , Alberta
Do you remember the cost of the new actuator?
Zenstream1 is offline   Reply With Quote
Old 08-05-2015, 09:00 PM   #19
"Cloudsplitter"
Question
Anyone know why AS no longer offers disc brakes?
They did at one time.
I have surge discs on the boat trailer that seem to work pretty good.
Old 08-06-2015, 04:19 PM   #20
New actuators vary in price, depending on the source, but basically a little over $ 600.00.
Andy Rogozinski
Inland RV Center
Corona, CA
Vacuum brakes JOHNMARDALL Brakes & Brake Controllers 20 08-23-2015 06:00 PM
Time for new brakes '77 LI Pets Brakes & Brake Controllers 11 04-03-2012 05:30 AM
Breakaway brakes Buffalo Brakes & Brake Controllers 5 03-31-2012 06:11 AM
