Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 11-29-2002, 02:41 AM   #1
suprtrker
suprtrker's Avatar
Profile:
Question Vacum Breaks
I have just got into this airstream stuff, so I need a little help.
I have relized that my Airstream has Vacume Breaks, so my question is this. Should I switch this over to Elic. or leave the breaks vacume. And if I leave them vacume is it hard to set my pickup up for this opration. Also maybe some one can give me some advice on how and where to run the vacume line, from off my pickup.
suprtrker is offline   Reply With Quote
Old 11-29-2002, 08:51 AM   #2
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
welcome to the forum,
do a search under disc brakes. a couple of the guys here have quite a bit of experiance with vaccum brakes. and like them.
i'm sure they will chime in here soon.....
john
Old 11-29-2002, 11:39 AM   #3
FrankR
Profile:
Vacuum disc brakes are the best
Disc brakes have many advantages over other braking methods. A vacuum source is very simple. The tow vehicle will need to be plumbed from the engine to the Airstream with a line dedicated to providinf vacuum to trailer.....
OR an 12volt electric vacuum pump can be sourced at many auto/trucl salvage yards. All vehicles with a turbo require a vacuum source for power brakes and heat/airconditioning systems. The electric pump are about $45. The vacuum pump maybe located under and near the front of an Airstream trailer. Power for pump maybe supplied by 12volt power from tow vehicle that supplies power to charge trailer batteries. Vacuum pump uses very low power.
Of course there is a change over master cylinder that is a 12volt electric motor.
Visit Idaho The people are great
FrankR is offline   Reply With Quote
vacuum brakes 1977 landyacht acme Brakes & Brake Controllers 35 04-24-2003 08:19 PM
Vacuum Disk Brakes APB Brakes & Brake Controllers 1 04-07-2003 12:14 PM
vacuum power disc brakes trumpwer Brakes & Brake Controllers 1 03-09-2003 01:08 PM
Rotors for vacuum disk brakes wvmiller Brakes & Brake Controllers 4 10-21-2002 05:43 PM
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 6 08-26-2002 10:20 AM
