Old 02-17-2008, 10:52 AM   #43
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
You can see the Ford approach in the schematic at the bottom of this post (note the use of relays, as previously mentioned above):
http://www.airforums.com/forums/520826-post6.html
The table in the same graphic has information on wire gauges and maximum currents, but I would recommend many of their wire gauges be heavier by one step.
The brake discussion is interesting because they work on current and as long as you can lock up the brakes at some high setting of the brake controller, it doesn't matter if you lose a little voltage in the wiring. Maybe that's a good diagnostic--if you can't lock the brakes even at the highest controller setting, either you have a weak controller or your wire is too small (it could be the wire to the controller, from the controller to the 7-way connector, or the wiring in the trailer).
Zep
Electric Brakes 61 Bambi Brakes & Brake Controllers 5 05-17-2007 06:13 AM
electric brakes Al1 Brakes & Brake Controllers 16 02-08-2005 07:59 PM
more about electric brakes openroad Brakes & Brake Controllers 14 01-03-2005 07:51 PM
Electric Brakes dbaverb Brakes & Brake Controllers 7 09-12-2004 08:27 PM
How can I test my electric brakes? Swingking Brakes & Brake Controllers 7 03-04-2003 06:14 PM
