Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 01-12-2007, 08:32 PM   #43
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
I have drums on my 60 trdwnd and there ok .they do have the issues that Phil has mentioned ,but not any real problems at all .I completely agree that
disc brakes are superior in every way .reduced fade (if any) and great
stopping ability .Travelall has discs on it now ,never kept drums on any vintage vehical Ive owned ,always converted to disc.On restorations ,
Ill install 4 wheel disc conversions if available ,the customers are amazed at the stopping ability and how smooth it all works .On any larger trailer I
definately would upgrade to disc brakes.Alot of weight to stop, so go with
the best setup you can .I agree with uwe as well, on the off ramps and other types of driving ,discs are just better .the travelall has the Fuller 5 speed and so downhills are no problem as excessive use of the brakes is not needed . I use the trans and gearing to control the speed ,just like the big trucks do .this is my own experience with my rig ,others will have different experiences.My goal is to not have to be on the brakes alot if I don't need to be .Discs can benefit all airstreams small or large .The trailer industry is now
starting to come around to the benefits of disc at last .
Scott
scottanlily is offline   Reply With Quote
Old 01-12-2007, 09:04 PM   #44
axleman
Commercial Vendor
Profile:  Currently Looking...
Somewhere , Indiana
Good!
Well said Scott!
Regards,
Henry
axleman is offline   Reply With Quote
Old 01-12-2007, 10:33 PM   #45
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Hi, I don't disagree that disc brakes can be better, But if you don't need them why spend the time money and effort to change to disc? I have been through many western states and through lots of mountain roads with no fade problems. Matter of fact, on my last trip through Oregon, I was comeing down a long fairly steep grade, I was in third gear [manually down shifted] and only touched the brakes a few times all the way down hill. When I got to the bottom of the hill while coming to a complete stop I noticed that I needed more pressure on the tow vehicle's brake pedal. I also noticed the brake controller light was out. [no trailer brakes at all] Bottom line I found a bad connection at my 7 pin connector. [ground wire pin] Cleaned the connector and back to normal. Now that I've taken you through the scenic route, I will get to the point; And that is, if you are one of those drivers that drags your brakes all the way down hill you will overheat and burn up any brakes made on this planet. So a lot of brake problems are directly related to driveing skills. And of coarse improper mantainence and adjustment of the brakes and controllers. Going to disc brakes will eliminate one of these adjustments.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 01-12-2007, 11:37 PM   #46
scottanlily
Hello Bob ,
I agree with you there ,We towed from nebraska to Ca and took a long venture thru Arizona to prescott and south down into congress and
had no issues with the trailer brakes ,and going down off the high pass
(quite a drop down ) we were good ,what a view though ,and its like going from the trees one minute and desert the next .The gearing down and good driving skills do make the difference .I myself still have drums ,and will for
a while as they are working fine and do the job .Again ,the discs give you much more in the braking than drums, I don't disagree with your thoughts
on proper braking /operation of the TV and trailer.
Scott
Old 01-13-2007, 08:52 AM   #47
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
I needed them!!
It only took one panic stop when a woman overran the stop sign at a mall exit and stuck 3' of her hood out in my lane to convince me that I did the right thing in converting to disks. With drums, it would have been either hit her or head-on with the opposite lane. I stopped inches short of hitting her. This just happened last week. With drums, I would be processing insurance claims right now.
I have driven plenty of mountains with drums with no problems; drums will do the job under ordinary circumstances. Where disks shine is the exceptions.
A friend recently converted his 31 Limited to disks, largely on my recommendation. Both he and his wife separately came to me thanking me for being the final push that had them convert. The interesting thing is that the wife, who never has even driven the truck, let alone towed, raved about the smoothness of the disks. She said that she could always feel the drums, especially on wet surfaces, but has never felt the disks. That confirms my experience that towing with the disks is like driving the tow vehicle solo.
Best money I have ever spent on a trailer.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 01-13-2007, 09:07 AM   #48
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
I think discs are better, but I too have had at least 2 extreme braking situations simialr to John's and in both cases our drums worked flawlessly and smoothly. The Suburban and the trailer felt like one piece, working in unison. The brakes on the Safari are still fairly new (maybe near 7k on them), so I can't say how they will behave as they wear further.
Old 01-13-2007, 09:17 AM   #49
Pahaska
Pahaska's Avatar
Images: 12
But ...
Disks have about 50% more stopping power than drums. Given that I stopped just a couple of inches short with full pedal, I'll guarantee that with drums, I would have hit her. That, to me, is the difference that makes discs worthwhile.
The bonus is the smoothness of the disks and no need to adjust for driving conditions or rusty drums after the trailer has sat for a while.
In my storage facility, I have to go down a sharp decline a few yards from where the trailer is stored. After the trailer has sat for a while, with drums, I had to fully back off the controller to keep the drums from locking up. I never have to touch the disks.
John W. Irwin
Old 01-13-2007, 12:07 PM   #50
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
Big Rigs
Any of you all have any experience with big rigs? I was looking at some of the trailers out in the yard where I work. They all have drum brakes, but they're massive. And the drums are totally open on the back to let heat and brake dust out. The drum linings are really really big with a lot of swept area. And, they use a mechanical lever arm hooked to a big air cylinder to actuate them, so they get lots of clamping force.
I know they stop OK. But I guess you couldn't do a system like that on something with wheels as "small" as what our travel trailers use. As well, if you lose air pressure, you just lost the brakes.
All systems are trade offs. I always heard drums stopped just fine on the first stop. But once they start warming up, that's pretty much it. But, my old '65 Plymouth Sport Fury had non power assisted drums. You had to put both feet on the pedal and really push, and that freight car still didn't want to stop. I took the spindles and vacuum booster off a '69 New Yorker and put on it and converted it to power disks. Made a big difference.
I've never towed out west. I have driven a 4-cylinder Cavalier over some 11,000 foot passes out there though. I'd want to have good brakes coming down the other side!!
I know with the new disk rigs you have the added complexity of the E over H unit, but I still think they're the way to go. I'm really partial to the setup that Towbrake makes, where it's just a big linear actuator. Very simple, not much to go wrong with it. There's no pump, just a giant servo that pushes the piston on a standard automotive type master cylinder. It's a big unit, but not so big you couldn't stick it under a gaucho or something. But I've not heard of any of the others failing on a guy either.
Anyway, to each their own. They'll all work well if you drive right. But I'm gonna go new disks to replace my old worn out disks.
Cheers!
- Jim
JimGolden is offline   Reply With Quote
Old 01-13-2007, 12:55 PM   #51
Craftsman
Guest
Profile:
Posts: n/a
Just wanted to throw this out there. I won't sell the Actibrake controller( it's new) but if someone really is doing a self install disc brake conversion, they can have it for free for the cost of packing it up and shipping it. BUT... Mike Lewis has the first right of refusal because he contacted me first about it.He may or may not need it. Just PM me.
Old 01-13-2007, 01:03 PM   #52
axleman
Commercial Vendor
Somewhere , Indiana
What a deal.
At Axis we sold that part alone for $500.00.
What a deal for someone. You're a true sport.
Best Regards,
Henry
Old 01-13-2007, 04:31 PM   #53
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
You don't need a parachute unless your going to jump out of the plane.
You don't need disc brakes, until you do.
But when you need them, and don't have them, then what?
Safety, Safety, Safety, is the name of the game.
Do all you can do, and more if possible.
There are far to many inconsiderate unsafe drivers out there. Be equipped the best that you can.
Insurance is a "HUGE" waste, until you need it. Brakes are a waste too, until you need them.
Disc brakes are not a waste, but it's the best that can be done by todays standards.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 01-13-2007, 04:55 PM   #54
Steve Heywood
Steve Heywood's Avatar
Profile:  1997 30' Excella
Ferndale , Washington
I drove tractor/trailer 30 years ago. The brakes may look big, but considering the weight involved (80,000 lbs) are marginal. It's very easy to fade them to the point of being worthless, it's even possible to catch them on fire!
As for "no air=no brakes", not so! Pure air brakes use what's called a spring brake. Air moves the mechanical rod in one direction to apply the brakes, unless air is present a spring will move the rod in the opposite direction. That's why you hear a loud wooshing sound whenever a truck parks, they dump the air from the system setting the spring brake which acts as a parking brake.
I hope my simple explaination made sense.
Steve Heywood
Ferndale, WA
2005 Ford F250 CC Powerstroke
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 01-13-2007, 05:11 PM   #55
Craftsman
Guest
Profile:
Posts: n/a
Actuator is spoken for.
jack
Old 01-13-2007, 08:07 PM   #56
WayWard Wind
WayWard Wind's Avatar
I'm a long way from being an auto mechanic and know very little regarding what's best in brakes, but for me and my house, we had the A/S factory change out the brakes on our 04-25' Safari this summerl. It was to say the least , NOT CHEAP . Have driven 12,000 + miles since and really like the "feel". both in the stopping ability and mind set. That's what it's all about to me.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 06:26 PM
disc brakes overlander Brakes & Brake Controllers 10 01-26-2003 12:29 AM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 08:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 08:56 PM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 04:04 PM
