Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 01-10-2007, 01:33 PM   #1
Steve & Susan
Steve & Susan's Avatar
Profile:  2005 28' International CCD
Willoughby , Ohio
Upgrade to Disc Brakes
Hello all -
I am considering upgrading the brakes on our 2005 28' CCD to disk and I am asking for advice both pro and con.
Has anyone decided to do this - if so, why?
Has anyone decided against it - if so, why?
Thanks!
Steve & Susan
2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 01-10-2007, 01:39 PM   #2
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
I was just getting ready to start a similar thread. We are considering the same conversion. I have talked to a couple of Airstream owners who have the factory installed discs and say that they are great. I, also, am anxious to hear from someone who has done the conversion from drums and get their input.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 01-10-2007, 02:45 PM   #3
rickandsandi
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Hey Guys, this subject has been beaten to death. Use your search function and you will find some very indepth threads on this subject. You will find everything from have to do it to don't change. Check it out!
SEARCH!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
rickandsandi is offline   Reply With Quote
Old 01-10-2007, 02:59 PM   #4
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
I agree Rick.
A good tool is using advanced search if you have any idea who has posted on the topic before. Enter your keyword(s) in that field, but add the username in the field just to its right. Disc brake threads have gone to the length that 2airishuman has discussed wear-in in detail. Hey, there's a thought ...
Search away mi amigos!
Old 01-10-2007, 03:15 PM   #5
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Steve, I considered it, but the cost seemed hard to justify given that I don't do a whole lot of mountain towing. It'd be great to have with an RV your size, but to me cost drove the decision, understanding that my brakes currently are perfectly safe and work well.
If I had to replace the axles or the brakes outright needed to be overhauled totally, I'd have thought a bit harder about it.
Old 01-10-2007, 03:51 PM   #6
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Originally Posted by szy8xj
Hello all -
Thanks!
Actually the cost to upgrade to disc brakes is not that much.
However, since you don't have an actuator, you must add that to the system.
That one item doubles the cost of the disc brake kits.
Many owners are upgrading when they change out the axles.
Some are also upgrading when it comes time to buy new magnets or shoes for the electric brakes.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 01-10-2007, 07:33 PM   #7
Steve & Susan
Willoughby , Ohio
Sorry -
I must be using search incorrectly because I couldn't find the threads you mentioned - I'll try again.
Steve & Susan
Old 01-10-2007, 07:58 PM   #8
Phil Gobie
Phil Gobie's Avatar
Profile:  1977 31' Sovereign
Miami , Florida
I did mine a couple weeks ago. Big difference in the smooth consistent stopping power. I am in south Fla. no mountains here but when you are going 70+ and its time to stop it does it right now! I would do it again.
Phil Gobie is offline   Reply With Quote
Old 01-10-2007, 08:07 PM   #9
JimGolden
JimGolden's Avatar
Profile:  1977 31' Excella 500
Do it!
Disks are superior in every way. If you've got the green, make the change and never look back. I am.
(Actually I've got disk brakes now, but I'm replacing them with a new system)
Find the "Trailer Life" article where they took a 30ish foot 5th wheel with drums and a 3/4 ton Dodge, tested it thoroughly, then retrofitted it with an aftermarket disk conversion kit, and tested it again. Disks stopped in nearly half the distance of the drums. Disks don't fade like drums either.
Drums work good. Disks work better. Like stated above, you can search/research it to death. But if the money doesn't bother you, do it and know you've got a better system.
- Jim
JimGolden is offline   Reply With Quote
Old 01-10-2007, 09:01 PM   #10
moosetags
moosetags's Avatar
What kind of money does a disc conversion cost today on a dual axle Airstream?
Old 01-10-2007, 09:50 PM   #11
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
For now staying with drum brakes.
Hi, I am happy with my drum brakes and don't plan on changeing. And I have asked for those of you switching to disc brakes to UPS your new drum take offs to me for the UPS charge. If the drum system is so bad, I'm sure you would give me your drums free. Then I can take four drums to the machine shop to have them balanced and installed on my trailer with vertually no down time. And have a spare set of brakes waiting for the originals to wear out.
Still waiting for that PM message stateing that those lousy drums are on their way to my home VIA UPS.
Another thought, maybe the disc brakes would be better for those who have all three of these things: 3/4 ton or larger tow vehicle, 7,000 lb GVWR or heavier trailer, and Hensley Arrow Hitch. And those with smaller, lighter, trailer / tow vehicle combinations will do just fine with drums.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 01-11-2007, 04:44 AM   #12
Steve & Susan
Willoughby , Ohio
Moosetags -
I contacted the factory and they told me about $2400 plus tax and I'd need an upgraded brake controller.
Steve & Susan
Old 01-11-2007, 05:12 AM   #13
nohillgrish
Stray
Profile:  1987 32' Excella
Springfield , Missouri
Even though the subject has been "beaten to death", I switched in November on my 32' Excella and I feel it's well worth the money. I had been considering for some time, but final straw was performance of drum brakes on trip to New Mexico & Colorado this past summer. No real tests yet as far as mountain driving, but I am very satisfied with smoothness and consistent performance of the discs so far. So far, I would definitely do it again. I also changed to a Hayes-Genesis brake controller that appears to operate very well with this system.
Stray
nohillgrish is offline   Reply With Quote
Old 01-11-2007, 05:40 AM   #14
LI Pets
Silver Mist
LI Pets's Avatar
Riverhead , New York
Moosetags -
If the factory wants that, figure half as much elsewhere.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
LI Pets is online now   Reply With Quote
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
