Old 07-24-2016, 05:25 PM   #1
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Typical drum brake shoe replacement interval
I have 2015 27FB with Nev-R-Adjust brakes. AS is about 7500 lbs loaded for camping. I have done about 20k miles.
How often are people needing to replace the shoes? Obviously depends on lots of factors, miles, how fast you tow, the weight of the trailer / drum size, major grades traversed regularly etc.
Just want to get an idea what others are seeing.
Thanks.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 07-24-2016, 05:44 PM   #2
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
2015 23FB that has rolled a good ride so far. Dropped it by the dealer this week for a bearing pack and a brake inspection. That is the first step. From there it depends, but you don't know if you don't look. Pat
Old 07-24-2016, 07:26 PM   #3
megandrudy's Avatar
2011 34' Classic
Sebring , Florida
I have a 34' 2011 with never-lube bearings and self adjust which does not mater all brake shoes wear some more than others depending on conditions, but what does make a difference is the magnet bracket where it mounts onto the backing plate if this is rusted or binding it Will cause premature wear if it is not returning to center after applying brake pressure. This happen to me,it sometimes caused lockup intermittently and definitely caused premature were. Any time you pull the drum off check for movement and apply a very small amount of brake grease on the pivot for the magnet bracket and where the shoes make contact with the backing plate. FYI if you need to replace the brake shoes you can bye the whole backing plate and shoes with magnet for a little more money and you have everything new except for the drum,this needs to be inspected also for wear.
David, Debbie, Jenna-Leigh
and our 2 dogs....
Meg and Rudy!
megandrudy is offline   Reply With Quote
Old 07-24-2016, 08:14 PM   #4
Ohiobrits's Avatar
Howard , Ohio
Thanks for the input. It's been maybe 20 years since I worked on drum brakes (how quaint &#128512 but it's probably time to take a look.....
Old 07-25-2016, 11:31 AM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I have 22000 miles on our 13 31' classic, the shoes are like new, the exhaust brake on the dodge helps....
tjdonahoe is online now   Reply With Quote
Old 07-25-2016, 01:24 PM   #6
Anna Maria , Florida
I just had the brakes inspected while at JC on our 2013 30' Intnl. The service manager said it really wasn't necessary since I should be able to get over 50k miles without a problem before needing replacement. I insisted that they pull one wheel anyway to inspect and sure enough they are like new with about 18k miles on them.
franklyfrank is offline   Reply With Quote
Old 08-03-2016, 10:27 PM   #7
PKI
PKI's Avatar
With about 25K on the trailer our inspection showed the brakes were worn. Still need to inspect the parts to see if something odd is in play. Pat
Old 08-04-2016, 08:24 AM   #8
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You won't have to replace your brake shoes if you keep your foot off the brakes!
Old 08-04-2016, 08:48 AM   #9
PKI
PKI's Avatar
Can't stop for the pie if you don't use the brakes. Pat
Old 08-04-2016, 11:01 AM   #10
Ohiobrits's Avatar
Howard , Ohio
My kind of logic....😀
Old 08-04-2016, 11:15 AM   #11
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
2003 Classic.... never had to replace shoes for worn out linings.
Dexter replaced because bonding failed at 5k, a good case for yearly inspections.
(No blueing or evidence of overheating.)
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-05-2016, 03:33 PM   #12
PKI
PKI's Avatar
Reviewed the brake assemblies today. Could have made a few more miles, but the magnets showed wear and it was definitely time to check. Good to go. Pat
Old 08-12-2016, 10:20 AM   #13
Redmond , Washington
We have about 18,000 miles on our 2015 23 FB FC. I took it in today for the annual wheel bearing packing. The tech showed my the magnets are worn and have scored the drum surface. The shoes are not worn very much at all. I use engine braking with our EcoDiesel and am careful not to over use brakes. But we do have serious trips to Newfoundland from Seattle with many mountainous areas along the 13,700 mile route last year. Other local trips often involve modest mountain passes, too. But less than 20k miles seems unusual to me.
I will attach photos.
Any comments observations and experience is much appreciated. I learn a great deal at this Forum!
Name:	Brake magnet wear 8 12 16.jpg
ID:	268888   Click image for larger version
Name:	Brake wear Aug 12 16.jpg
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 08-12-2016, 11:24 PM   #14
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
They look normal to me for what I can see from the picture with 20000 miles ,they aren't going to be new,if working good run them..
Drum Brake Cylinder replacement -Autozone parts have issues MrJ Argosy Motorhomes 2 12-09-2015 06:58 AM
P-30 Transmission Fluid change interval crazeevw General Motorhome Topics 11 12-08-2011 03:59 PM
New Brake Shoe Problem cooney Brakes & Brake Controllers 25 04-13-2010 11:41 AM
Wheel & Hub Service Interval moosetags Axles 15 07-10-2007 08:38 AM
brake shoe retainer springs and pins.. safari25-05 Brakes & Brake Controllers 1 04-08-2007 05:17 PM
