Old 03-21-2006, 06:38 PM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Question two axles, different brakes
I've seen posts that "alledge" that some of the bigger [older] trailers have been found with electric brakes on one axle and hydraulic on the other. I am completely befuddled by this setup.
What is the purpose?
How are they harmonized?
Was there some kind of strange brake controller used for this setup?
If you were doing a new set of axles, would you repeat this arrangement or go one way or the other, totally?
If you did mix the brakes, is a special brake controller required?
Old 03-21-2006, 07:05 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The brakes worked with one axle working from the hydraulic brakes on the tow vehicle (not clear if the brake fluid actually flowed between them) and the other axle with the big resistor spring under the hood and handle on the dash. Supposedly this was a simultaneous actuation.
Old 03-21-2006, 07:06 PM   #3
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
My 63 Overlander came with this setup. There was a master cylinder type device on the tongue, which tied into the rear axle brake line on the tow vehicle, if I understand correctly.
The other axle had conventional electric brakes.
I have no clue what they were thinking back then. I guess progress had to be made somehow, so perhaps that was the starting point?
Uwe
www.area63productions.com
Old 03-21-2006, 07:27 PM   #4
It was a "dual system".
Actually, if it was hooked up correctly (most were not), it worked rather well.
Also it was a transition between hydraulic brakes and electric brakes.
Problems were many, in that your had to have an electric brake controller and also tie into the hydraulic system of your tow vehicle brakes, at the rear axle.
Royal pain.
AirstreamCentral.com
Old 03-21-2006, 07:43 PM   #5
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
HI Andy, How did they tie the two hydralic together Andy without getting air into the system?
1977 31' landyacht Sovereign
davidh is offline   Reply With Quote
Old 03-21-2006, 07:55 PM   #6
An umbilical hydraulic hose was connected to the tow vehicle, permanently.
The trailer end had a metal fitting that was held in place on the master cylinder that was on the front of the trailer, with a clamp.
I have an oldie here. I will post a photo of that arrangement tomorrow.
AirstreamCentral
Old 03-21-2006, 08:27 PM   #7
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Thanks Andy, I look forward to seeing that photo, thanks again..
Old 03-22-2006, 09:55 AM   #8
davidh
Photo of the old hydraulic master cylinder and clamp, that Airstream used many moons ago.
Old 03-22-2006, 06:53 PM   #9
1977 31' Sovereign
davidh's Avatar
Kalispell , Montana
Thanks Andy I can see were that would be a real pain, thanks again Andy..
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
Disc Brakes? J.Hemingway Brakes & Brake Controllers 2 08-22-2002 07:56 PM
Heeeelp! My brakes have failed...anyone have a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 03:04 PM
conversion from vacuum/disk to electric brakes excelladep Brakes & Brake Controllers 2 05-30-2002 11:54 AM
