Old 05-23-2008, 09:06 PM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Turning electric drums
I'm in the process of replacing 3 backing plate assemblies and am looking at the first drum I pulled off. These units had round magnets and the new backing plates have oval magnets. Should the drum be turned if the armature surface is uneven but the brake shoe surface has no irregularities? If so, I sure picked the wrong day tomorrow to have it done.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 05-23-2008, 09:12 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Craig, both friction surfaces need to be straight and relatively smooth. A gouged friction area for the magnet will cause the brakes to apply unevenly, and the new magnets will wear into the grooves that are present.
Old 05-23-2008, 09:17 PM   #3
Mixing round and oval magnet backing plates will give you a brake pull.
You cannot mix the two.
Old 05-23-2008, 09:35 PM   #4
davidz71's Avatar
1986 25' Sovereign
Thanks Terry and Andy. I thought this might be the case. Andy, the fourth backing plate was replaced last October after my east TN. brake mishap. It was a Dexter oval magnet just like the other three I am working on now.
Craig
AIR #0078
3.73 rear end
Squeaking Drums? rambn Brakes & Brake Controllers 11 05-22-2007 01:57 PM
New brake drums or studs????? bhayden Brakes & Brake Controllers 2 05-08-2007 04:13 AM
New drums to correct running gear imbalance? TomW Brakes & Brake Controllers 31 09-25-2006 08:57 AM
Turning radius rmcdon8848 General Motorhome Topics 7 10-14-2004 05:45 AM
Brake drums Airstream 1975! Brakes & Brake Controllers 3 03-12-2004 11:27 PM
