Old 12-18-2009, 11:41 AM   #1
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
transmission revving high w. brake controller
friends -
hope this is the right forum [otherwise in TV section? ]
anyway, the details are as follows:
TV is '09 f-150 supercrew 2wd w/tow package, tow/haul option etc
AS is 22' ccd model
brake controller is from primus, installed by local AS dealer
situation: the tv and brake controller work great on level and uphill climbs; also on moderate downhill slopes.
however, on some steep downhill sections the TV transmission will go into a high-rev mode when i use the brakes. there is no wobble or sway from either the TV or the AS. I can usually kick it down but the high revs worry me.
since i have the tow/haul option should i be driving in "D"? or in another gear?
has anyone else had this same problem?
i read somewhere the the ford transmission will go into high rev but that there is a safety mechanism which prevents motor damage.
any input would be greatly appreciated,
az-streamer
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Don’t Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Old 12-18-2009, 12:59 PM   #2
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
I tow with my 07 F-150 sometimes. I tow with the tow/haul on and in D.
I have never had it rev when braking. Have you asked the Ford dealer about this or is anything in your manual?
Regards,
joe
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 12-18-2009, 01:54 PM   #3
2009 25' SS International
Pasadena , California
Isn't engine braking a good thing? You can probably avoid it by turning off tow mode...
flmgrip is offline   Reply With Quote
Old 12-18-2009, 05:40 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
When you are using Tow Haul Mode the trans will down shift during braking. This is a design feature to reduce the ware on the brakes. The steeper the hill the sooner and greater the down shift may be. If things are working right the trans should down shift one gear at a time as you slow keeping the engine RPMs high enough to produce effective engine braking.
I don't think you have a problem you just have to get used to the new design.
2004 Excursion 4x4
Old 12-18-2009, 07:23 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My Tundra downshifts when I hit the brakes on long downhills. I consider this a good thing since the engine breaking will reduce the amount of brake I need to keep the speed I want.
Richard
Old 12-18-2009, 07:40 PM   #6
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Engine braking is a good thing. In the Tow/Haul mode and possibly under certain decents the logic built into the transmission control module will allow for engine braking. In the case of over-reving it would then upshift before you blow the engine. All of these scenereo's have been tested and optimized for as many possible situations you could find yourself in. When its in Tow/haul mode that tells the ECM and TCM the truck is under heavy service and to behave a different way.
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 12-18-2009, 07:55 PM   #7
_
post MORE details.
what speed?
what RPMs?
what grade?
my understanding is the tranny will down shift TWICE in t/h mode...
1. one time for STEEP declines
2. and a 2nd time IF the truck brakes are applied downhill.
touching the go pedal briefly will up shift.
________
and this will happen when NOT towing as well,
so u can test the system without the trailer involved.
that would be using the "haul" mode...
cheers
2air'
Old 12-18-2009, 11:31 PM   #8
Images: 20
thanks to all for the replies.
i feel a little better knowing that this is probably a normal reaction to hauling a substancial load down a hill.
on a decline, i try to keep my speed within the posted range, or even lower.
the transmission usually runs around 2 on the level but revs to about 4 before i can get it to drop back down.
the hills are all regular highway - i guess the worst at about 5-6 degrees down. ik don't speed - not good for the AS the TV or my nerves.
this happened on a recent trip my wife and i made to dead horse s.p. in cottonwood az. while driving on I-17.
this has not happened at all when i not towing the as.
az-streamer
az-streamer
Jon & Deb
FCU WBCCI #1601
FAST automatic overdrive transmission controller wmarsha Tow Vehicles 0 09-01-2009 09:38 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
Which Brake Controller jm2 Brakes & Brake Controllers 11 11-18-2008 11:46 AM
Transmission Temp too high? Silver Threads Tow Vehicles 19 05-10-2007 12:04 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
