Old 05-27-2007, 01:28 PM   #1
safarinight's Avatar
2004 25' Safari
Columbus , Ohio
Trailer Brakes - Drum to disk upgrade
My wife and I are considering upgrading our 04 Safari's brakes from drum to disk next year, so we would like to hear from anyone that has already upgraded, or thinking of upgrading.
Thanks.
safarinight is offline   Reply With Quote
Old 05-27-2007, 01:56 PM   #2
Dwight's Avatar
1999 34' Excella
Joshua , Texas
brakes...
Terry, it is worth the effort to convert to disc. I only know of 2 places to have it performed correctly, the factory and Roger Williams Airstream. Call and talk to Robert Haberzettle or David Tidmore at Roger Williams Airstream and they can tell you more about cost. Their number is 817-569-0050.
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 05-27-2007, 05:09 PM   #3
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Hey I didnt know....
They make Electric Disk brakes....?
Mrcrowley is offline   Reply With Quote
Old 05-27-2007, 05:32 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
The signal is sent thru the umbilical electrically. A hydraulic actuator is put into the Airstream as part of the conversion. A number of the available systems are incompatible with brake controllers. The Kodiak system that Airstream uses is about the only one to use. Search the forums for a number of good discussions. Terry would use the factory of course. I fully concur with what I've heard about David Tidmore!
5 meter Langford Nahanni
Old 05-27-2007, 06:47 PM   #5
2004 25' Safari
Columbus , Ohio
Disk Versus Drums
Airstream Life's Summer 2006 issue has an article on page 66 titled "Disk Versus Drums". This article is the motivation behind our decision to convert. We know people have been towing much larger trailers then our 25' safari without incident for years, but the idea of going through the mountains with the possibility of loosing the trailer breaks due to overheating is un-nerving, and we are planning trips to the coast that will require us to be prepared.
The plan is to drop the Safari off at the factory next year before the camping season starts. Since the Kodiak hydraulic actuator needs to be mounted inside the trailer we decided to give up the compartment next to the water heater. This would give us curb side access to keep an eye on it.
My question to the forums is how much different are the disk from the drums when stopping? Has anyone already had the conversion done?
Thanks everyone for the feedback.
Old 05-27-2007, 08:24 PM   #6
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Terry: Send a PM to Bilouie as he just had his done at the factory on a 93 excella and likes the results.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 05-27-2007, 08:33 PM   #7
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Mind if I jump in here?
I'm having new axles put on with disc brakes. However, I will have to install the hydrolic pump and brake lines.
I've not done any reasearch yet on this part. Any pointers?
Can you get pre-made brake lines to keep me from having to cut and flair them?
-Tim
theVAP - Airstream Podcast
Old 05-27-2007, 08:56 PM   #8
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Terry,
The difference is quite staggering. Both systems will stop a trailer, but the discs are much smoother, and substantially more powerful. The trailer can stop the entire rig, repeatedly, on steep down grades. I tried...
Having had a 25ft TradewWind, and having nearly lost it's brakes while descending Wolf Creek pass in CO, I vowed to find a better system than the electic trailer brakes. My research showed that the most capable system to fit my 1963 Overlander's new torsion axles was the Dexter disc brake setup with Dexter's own actuator. Some prefer the Kodiak, because Airstream uses it oem. I just liked the Dexter equipment better due to it's fixed 4-piston caliper design, over the Kodiac's single piston floating caliper design. I prefer the Dexter actuator for it's lightning fast response time, and it works with most common brake controllers. The brake performance is nothing short of spectacular.
A positive side effect of the disc brake setup is the fact that inherently, the discs have a much better rotational balance then trailer brake drums, making the trailer ride smoother at highway speeds.
A disadvantage is the fact that hydraulic systems need maintenance, the brake fluid should be flushed every two years at a minimum.
Uwe
www.area63productions.com
Old 05-27-2007, 08:58 PM   #9
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
Tim,
Well stocked auto parts stores will have brake lines in varying lengths. If you need elp, let me know, I have a double flaring tool. It is easy to do once you remember to put the compression nut on before making the flare.
Uwe
Old 05-27-2007, 11:04 PM   #10
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Stopping Power
Uwe,
All that stopping power is exactly why I like mine. I have about 16,000lbs of stopping power in the trailer and about 11,000lbs in the truck. a total of 27,000 lbs. Currently My truck and trailer weight about 16,000lbs combined.
Lots of reserve. It will stop fast. I have suprised a few following me.
Michelle TAC MT-0
Sarah, Snowball
Old 05-27-2007, 11:11 PM   #11
the ponz's Avatar
Detroit , Michigan
for those that have had the discs installed, what was the cost to convert from drums?
86' 31' Sovereign
the ponz is offline   Reply With Quote
Old 05-28-2007, 08:36 PM   #12
2004 25' Safari
Columbus , Ohio
Originally Posted by uwe
Terry,
Uwe - Your Wolf Creek pass experience is exactly what I'm trying to avoid. The ability to stop the TV with trailer brakes is something I had not considered so thanks for the pointer.
I like the Airstream installed system because it uses GM automotive calipers. Using off the shelf GM parts solves the parts availability issue, and ensures a multitude of choices and prices when replacement pads are needed.
Old 05-29-2007, 02:03 PM   #13
The cost depends on who will do the job.
If you do it, that's one thing. If you have a dealer do it, the door is wide open depending on their experience.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-29-2007, 02:16 PM   #14
We sell "complete kits," that are all inclusive including complete instructions.
http://www.inlandrv.com/parts/86200-...-brake-kit.jpg
Most suppliers sell just the disc brakes. You have to chase the rest of the parts.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-29-2007, 03:10 PM   #15
ljmiii's Avatar
2006 16' International CCD
New York , New York
I had Airstream upgrade my 2006 16' Bambi from drums to discs earlier this year. They installed the Actibrake/Kodiak combination they use on their other trailers. I found them to be very helpful and quite responsive to inquiries via email - they charged $1710.00.
The disc brakes have amazing stopping power compared to the drums. However, I have had a few issues. One, the Actibrake does introduce a 1/2 sec delay. Two, the actibrake does need to be calibrated to your tow vehicle & controller. And three, the actibrake draws directly from the DC current. I'm currently debugging a problem where my Prodigy thinks the actibrake has 'gone away' after a few minutes of driving without braking (ie shows .NC. or . . instead of .C.) if I tow with my airstream's power set to use instead of store. I think this is because when my refer is set to DC it draws too much power and is competing for amps with the actibrake...but as I said I am still debugging.
ljmiii is offline   Reply With Quote
Old 05-29-2007, 05:20 PM   #16
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
The main reason the disc work better is the hydraulic system. When the brakes have the same hydraulic pressure to each caliper you have a much better chance of getting equal pressure or not locking one wheel before the others. This means you will be able to achieve maximum breaking with out lock up. Not to mention the better balance of the disc.
Make sure the brake controller is compatible with the electric/hydraulic pump that you end up with. They are not all compatible. Some have a setting to remedy some of the delay. Also as for the person experiencing a delay be sure the system is bled correctly or this will also cause delay and can contribute to the brakes dragging.
You will find the difference is night and day!
Phil Gobie is offline   Reply With Quote
Old 05-29-2007, 06:31 PM   #17
JimGolden's Avatar
1977 31' Excella 500
Towbrake
Check out Towbrake's electric over hydraulic unit. Some excellent engineering in this unit. It's not a pump, but rather a large servo motor (linear actuator) hooked to a normal automotive master cylinder. I think it has a lot going for it.
Tow Brake Product 2
- Jim
JimGolden is offline   Reply With Quote
Old 07-15-2007, 09:19 AM   #18
fred bartlet's Avatar
2001 31' Excella
Bluffton , South Carolina
Disc brake conversion.
I just finished a two axle disc brake conversion on my 30' trailer. I used the Kodiak/Actibrake from Inland Trailer. The only problem I encountered was the backing plate for the disc brakes did not match up the the axle, as I used the 10-2 recommended positioning. I e-mailed Kodiak but with no reply, I just matched up the 4 holes to axle and marked the missing hole, then drilled the backing plate. Cast iron is easy to drill if you have a drill press. If you hand drill, use a center punch and drill into a soft backing.
I did not follow the hyd. line layout of the kit, but I made a trip to the dealer to see how AS does it OEM. In stead of the H layout, which I'm not sure it will work on the swing axles, I used the Y layout. I installed the Actibrake in the front tool box and ran the brake line back to the center line of the coach belly. Then I teed off to both sides, in front of the wheel wells and followed it back to each wheel. Hence, the Y pattern.
It was a tight fit to thread the flex lines behind the shocks but I added sprial rap to prevent chaffing the flex line. I had to add several new line lengths to the hyd. lines, but they are cheap at any auto store. Before one tries this project, be sure to get a brake line bending tool and some brake line wrenches. For layout of lines use lengths longer than required and bend a Z into the lines to takes up the extra length.
I've only towed once and the results are great. I also have the Prodgy controller that showes an open circuit when towing but it seams to work when used. ???? Cost, about $1,800 with tools and four days of labor.
PS I will not miss the ol-mechanical electric brake maintenace!!!!
Fred Bartlett
30' S/O 01 Excella, maple floors in Galley, HA Hitch, Hyd. Disc Brakes, P3 Controller, SS Kit. Bk Splash, LED RL's, 2K/Tri Fuel Gen's & RV on TT
04 Chevy HD, CC, D/A, Curt Magnum V Rec., Full Amsoil Syn.,Dual Filters, ARE, MX Topper with lift Gate Door, Bed Rug, TPS & Bk.up Camera.
fred bartlet is offline   Reply With Quote
Old 07-15-2007, 10:21 AM   #19
2003 22' International CCD
Whittier , California
Costs
The price for a two axle conversion at the AS factory in Jackson Center was in the $2500 range about a year ago.
bobkelly is offline   Reply With Quote
Old 07-15-2007, 11:08 AM   #20
1960 22' Safari
in the wilderness , The great Mojave Desert
Does anyone know if either system works with Fords intergrated tow command system?
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 9 07-12-2014 07:41 AM
Airstream trailer weights FrankR Link Archive 11 10-17-2003 07:09 AM
Wheel Bearing?? - - or - - Brakes?? overlander64 Axles 8 11-24-2002 12:13 AM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
