Old 10-18-2016, 02:20 PM   #1
2017 16' Sport
San Diego , California
Trailer Brakes
I just bought my first Airstream, a 2017 16ft bambi. My tow vehicle is a 6 cylinder Toyota Tacoma that is prewired for a trailer brake. What I need to do is pick a good trailer break box suitable for my application and do the simple connections. There seem to be many available and I'm hoping for some good recommendations for my application. Can anyone recommend a good unit? Darren
vintage65 is offline   Reply With Quote
Old 10-18-2016, 03:25 PM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The Tekonsa Prodigy P3 is a good brake controller.
If mounting it in the truck cab is a space problem they also make a wireless one that mounts on the trailer tongue. Has a remote to use in the truck cab.
Old 10-18-2016, 04:35 PM   #3
1974 27' Overlander
Baltimore , Maryland
I have a prodigy p3. Ordered the one with the adapter to plug directly into my tacoma. Dead simple install. Works well, though I find myself fiddling with the thing when changing from highway speeds to neighborhood speeds. Can't seem to find one setting that grabs enough on the highway without grabbing too much at low speed. May be user error.
1974 Overlander In Progress
TheGreatleys is offline   Reply With Quote
Old 10-18-2016, 06:22 PM   #4
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
p3 all the way.
It's what I use in my tundra.
Works great and had excellent customer service
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is online now   Reply With Quote
Old 10-18-2016, 06:39 PM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Tekonsha P3 is the minimum to consider.
TUSON Direclink is current state of the art.
1990 35' Silver Streak
2004 555 Cummins
Hensley Arrow. 9-cpm solo, 15-cpm towing
Old 10-18-2016, 07:34 PM   #6
KSA63's Avatar
2011 28' Flying Cloud
Ramara , Ontario
Trailer Brakes
Redarc Tow Pro.
You will not be disappointed.
Kevin
KSA63 is offline   Reply With Quote
Old 10-18-2016, 07:51 PM   #7
CRH
1995 25' Excella
xxxxx , xxxxxx
Another happy P3 user here.
CRH is offline   Reply With Quote
Old 10-19-2016, 08:25 AM   #8
2017 16' Sport
Thanks All, I purchased a P3 controller last night based on most of your feedbacks as well as excellent reviews online. Based on the Greatleys response I also ordered the exact wire harness for my Tacoma. Thanks again
Old 10-19-2016, 11:09 AM   #9
2016 30' International
Florence , Alabama
Tekonsha P3, don't waste time on any others. Should be a plug in harness that you can order for it to plug in to the Tacoma pre-wire.
joshjack is offline   Reply With Quote
Old 10-19-2016, 02:04 PM   #10
Alluminati's Avatar
St. Louis , Missouri
Same here.
I set the boost to 3 on the highway. First time off the exit ramp it grabs too hard, I click it down to 2. Then if I'm in a park moving slowly, I set it to 1. Just have to remember to return it to 3 once I'm back on the interstate.
The Morgans
1989 Avion 34VB, "QE3"
2008 Toyota Sequoia 5.7L "Tug"
(Is there no respect for an 8-ton GCVWR truck? *sniff* )
Alluminati is offline   Reply With Quote
Old 10-19-2016, 03:13 PM   #11
1974 27' Overlander
Originally Posted by Alluminati View Post
Same here.
Glad to know it's not just me.
Old 10-19-2016, 10:54 PM   #12
2007 22' International CCD
Trailer Brakes
Only issue I had installing mine was finding the plug under the dash for the adapter. It was twisted behind the harness. Be absolutely sure to properly connect the separate ground wire to a chassis bolt per the instructions. It will not work reliably without a good ground. I mounted the controller pocket with s couple screws into the lower part of the dash, just below the fuse box cover, so I can easily reach it on the road.
The only thing to watch out for is that the controller is always on, and long storage of the TV will have an extra battery drain through the controller.
Other than that minor detail, I really like the P3. It really is plug and play on a Toyota.
KE4GNK/AE
Emergency flashers apply brakes and ID brakes detree Brakes & Brake Controllers 12 01-23-2010 10:16 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 06:56 PM
Brakes Or No Brakes 62safari Brakes & Brake Controllers 3 01-24-2006 10:18 AM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 01:22 PM
