Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 01-03-2003, 08:55 AM   #1
MattyBoy
Profile:
Question Towing Without Breaks?
Hi Folks,
I just bought an 18', 1970 Caravel, number B18T0J108.
It is listed as 3000 lbs. gross weight and I need to move it a few hundred miles of mostly straight highway. I just put on new tires and do not know if the breaks work.
My question is how safe or unsafe is it to tow it home without using the on-board electric breaks. (I have a friend with a gigantic GMC monster to do the towing and I do plan on getting the lights, etc. working, but I'm nervous not knowing the answer to this question.)
I do plan to inspect/repair/replace all systems, but I need to get it here first.
Thanks for your advise.
Matthew
MattyBoy is offline   Reply With Quote
Old 01-03-2003, 09:14 AM   #2
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
to brake or not to brake
Does the truck you will be towing with have a brake controller on it? If so it would be just as easy to try the brakes since you will need all lites on the trailer to work to be legal anyway. I have found that most problems with trailer brakes are just loose or disconnected wires. You should tear them down and inspect them when you get to your destination though. All said your tow vehicle may be large enough that you won't even need the brakes, of course that may be illegal in your area. I towed my 22' Argosy without brakes for 100 miles or so when I first picked it up but I had a 3/4 ton truck and no hills.
Chas
Chas is offline   Reply With Quote
Old 01-03-2003, 10:17 AM   #3
MattyBoy
Profile:
Hi Chas,
Thanks for you help. The towing truck does not have a controller. I have looked over the trailer and see a number of loose wires and would prefer not livening up the 12VDC just to drive the breakaway. What I'm hearing from you is just take it easy and be careful, but only for that initial transport.
I absoultly will insure the chains are secure.
Thanks again.
Old 01-03-2003, 10:25 AM   #4
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Towing without brakes?
Greetings Matthew!
Welcome to the Forum and the world of Vintage Airstreaming.
I concur with Chas in regard to planning to try the brakes to see if they work. On both my '64 Overlander and '78 Argosy Minuet 6.0 Meter, the brakes worked perfectly once everything in the wiring was straightened out.
Vintage Airstream and Argosy trailers often are not wired to the current standard for connectors so you will need to be prepared to rewire the trailer end to match the tow vehicle. On my Airstream, the previous owner assisted in that operation; on the Argosy, I was on my own. Even as a do-it-yourselfer klutz, I was able to install the new trailer end and get everything working properly on the Minuet in less than two-hours. It is quite possible that the Caravel that you are picking up will have a round pin connector rather than the flat blade style connector that is more common today so you may be faced with either adapting or replacing the trailer end in order to be operational. The modern connector will be labeled with the color codes for the wiring - - my notes indicate the following:
White Terminal = Ground
Blue Terminal = Electric Brakes
Green Terminal = Tail/Running Lights
Black Terminal = Battery/Charge
Red Terminal = Left Turn/Stop Lights
Brown Terminal = Right Turn/Stop Lights
Yellow Terminal = Backup Lights
The above color codes should correspond to your tow vehicle's standardized wiring, but the colors will be different on the Airstream. The easiest method is to disconnect each wire from the trailer end and test its purpose with a 12-volt battery and aligator clips - - I used the battery from my garden tractor and the troubleshooting operation took less than 2 hours. The above operation resulted in full functionality of brakes as well as tail light systems, but the clearance lights needed additional attention before they were functional.
Another potential pitfall of towing the rig home is hitch height. If you are towing with a sport untility or most large vehicles, you will need a hitch with enough drop to keep from raising the tongue too high which result in dragging the rear bumper on the ground when uneven terrain is encountered - - depending upon where the dump valve is located, you might drag off part of that assembly if it points down toward the ground at the rear of the trailer as the one does on my Minuet - - I know this from experience as I drug the protruding part of the valve off of my Minuet as I exited the previous owner's driveway (fortunately the driveway was dirt so the damage wasn't as severe as it might have been).
Also, you may need to consider the need to have supplemental trailer towing mirrors for your tow vehicle - - the standard mirrors (even on my '99 Suburban) are not legally adquate for trailer towing. I have tried both the CIPA slip-on mirrors and McKesh clamp-on mirrors and prefer the McKesh mirrors as they provide a much better view of the surrounding traffic and obstacles.
Check the following URLs for some additional information on troubleshooting the car to trailer connection:
Standard 7-Blade Trailer Connector Wiring:
Troubleshooting the 7-Blade Connector Wiring
I would definitely encourage you to try to get the safety equipment fully operational as it is a question of liability should an accident occurr (IMHO).
Good luck with your new Caravel - - you are sure to find that it is an excellent sized trailer for impromptu trips.
Kevin
Kevin D. Allen
AIR #827
Old 01-03-2003, 10:52 AM   #5
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Slow down
And realize that your stopping distances will be much longer than if you had trailer brakes.
And lastly in the society that we live in you will be deemed at fault in any situation for towing (knowingly) defective equipment and not doing anything about it.
Life is a risky place. Be careful.
>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 01-04-2003, 10:41 AM   #6
MattyBoy
Profile:
Cable Layout
Responding to Kevin...
Thanks Kevin, I have the original cable with the Caravel and found a posting of the pinout someplace on-line (can't remember where now, unfortunately). It is entitled "7-Way Plug for 1966 through and Including 1981". Its a round connector with a big honking center terminal. The terminals themselves are all about 1/4 round pegs with one larger index pin (ground).
According th that, there is a discrepancy with your pinout: They have it as this:
Blue Terminal = Charge Line*** (center connector)
Black Terminal = Backup Lights***
Yellow Terminal = Breaks***
where *** = different from yours.
I just thought I'd throw that out there in case anybody has more input.
Old 01-04-2003, 11:36 AM   #7
overlander64
Anna , Illinois
Images: 106
Towing Without Brakes?
Greetings Matthew!
What you have found is the Vintage Airstream pin-out, and this is different from the current industry standard for the tow vehicles which is the pin-out that I included. This in addition to the round pin connector terminal is the reason that I suggested that you might want to be prepared to install and wire a new connector to match the new tow vehicle/trailer standard. (The round-pin connectors are still available, but the flat blade style is the preferred item with the modern pin-out standards.) I checked my records and the pin-out color codes that you have are what should be found on the trailer, but they will not match up to the current industry standard found in current blade type connectors - - the information that I have was posted by Charlie Burke to the Vintage Airstream Club Discussion List. I have quoted from his message at the end of this message.
There are a number of reasons that you might want to have the trailer wired to today's standard. 1.) It will simplify wiring the tow vehicle end - - if you have the factory connector it won't need to be changed. 2.) If you wire tow vehicle to match trailer, you won't be able to easily tow other trailers - - I often rent a car hauler for use with my collector cars and it wouldn't work with the "Airstream standard" of the 1960s. 3.) If you plan to tow any other trailers owned or retned, they will likely be wired to the modern pin-out standard. I have rewired my trailer connectors to the current standard to simplify the towing equation.
I have done this with both my '64 Overlander with the help of the previous owner, and with my '78 Argosy Minuet. Even with minimal assistance from the previous owner (light spotter) the rewiring of the connector on the Minuet took less than two-hours and provided me with working trailer brakes and functioning tail lights - - didn't have clearance lights but within a few miles most of them had begun to function as well.
Airstream's wiring code back then had three wire colors different from the current code. This difference can be found on 1966-81, except those built to Canadian spec's in 1969. The differences are:
Yellow is the brake output rather than backup
Black is backup lights rather than charge line
Blue is the charge line rather than brake output
The others remain the same as today's standard, which is:
Red is left turn and stop
Brown is right turn and stop
Green is marker lights
White is ground.
*The above is an excerpt from a message posted by Charlie Burke to the Vintage Airstream Club Discussion List on June 18, 2000.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 01-04-2003, 11:36 AM   #8
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
new/old
matty
i think kevin's post shows the new standard, and your post shows the old.
if you were to match the wires you have to the new standard everything should work on the first try.
that is assuming nothing was changed on your trailer over the years. might want to have some spare fuses along just in case...
lotsa luck!
john
Old 01-04-2003, 11:48 AM   #9
john hd
john hd's Avatar
madison , Wisconsin
Images: 40
in addition,
kevin is correct about "standardizing" your plug.
one other thing you may want to consider is with standard(new) wiring is if you ever have a break down.
you won't have any trouble hooking your trailer to a friends or passerby's truck to get off the freeway as many tow companys will not haul a truck with a trailer on it.
in my immediate family we have 4 trucks all wired to the new standard, any one of them could (and have) tow my trailer. if my truck were disabled.
we also have a full size wells cargo car hauler that is wired the same.
that way when we travel in a group any truck can pull any trailer.
john
Old 01-04-2003, 12:05 PM   #10
MattyBoy
Profile:
Wow,
You guys are really taking care of me. I feel like I'm in good hands. Thank you so much.
I will rewire the towing end of my factory cable to the current standard. The old towing end connector is corroded anyway and needs replacement. It does have spade type connectors and does not look original. I think somebody may have already done the rewire, but it is a sloppy job (overcut shroud, pealing tape, etc.) I'll rework the entire cable from the trailed connector on. I'll stop by an RV place and get a current industry standard tow end connector and do what you say.
Thanks again! You are making me feel really at home and like I may have a chance of getting this project done.
Matthew
Old 01-07-2003, 11:44 AM   #11
dmreilly10000
dmreilly10000's Avatar
Profile:  1953 25' Cruiser
Brandon (near reservoir) , Mississippi
Images: 14
I have towed my 26' airstreams w/o brakes and I do not advise doing it. On one trip from the deer camp to home, it started to rain very hard. When I had to come to a stop, the trailer pushed my truck about 30 feet through an intersection before coming to a stop. Luckily, it was in a rural area with no other traffic. In dry weather, I haven't had any problems.
I would definitely hook up the trailer brakes.
dmreilly10000 is offline   Reply With Quote
Old 01-23-2003, 05:07 PM   #12
wvmiller
Profile:
Towing wihtout brakes
Last summer, I forgot to hook up the vacuum connection for my vacuum power disc brakes, so I had no brakes in the trailer. I have a 31' Excella and tow with a 2001 Suburban 1500 series 4wd. I pulled from Charlevoix, Michigan to Grand Rapids (roughly 200 miles) without incident.
I don't recommend it, it is illegal, but it can be done.
Bill & Jeanne Miller
78 Excella 31 CB
St. Louis
wvmiller is offline   Reply With Quote
Old 01-23-2003, 07:51 PM   #13
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
This past summer I towed with everything hooked up, but set the brake controls to disable the Voyager from controlling the brakes, because I didn't like the way it worked. I was able to use the manual lever anytime it was needed. Hopefully my new Jordan will arrive soon, and I won't have a problem this season.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 01-23-2003, 10:24 PM   #14
Rik
Profile:
I tend to be a bit more relaxed than most folks about towing -- lotsa years towing lotsa stuff, including 20 years pulling doubles. I've towed dozens of travel trailers many thousands of miles without brakes. Just don't go too fast, and be ESPECIALLY careful going downhill -- always use a lower gear and go slow. I know that many people wouldn't tow without brakes. To each his own. No question, it's better to have brakes -- but they not at all essential, IMHO. However, if you are not comfortable towing without them, don't do it.
Rik is offline   Reply With Quote
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 09:05 AM
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 09:00 AM
Airbags and Towing with Car mcostanzo Tow Vehicles 0 07-02-2003 03:40 PM
Another towing question ipso_facto Our Community 27 03-22-2003 08:06 PM
