12-29-2014, 02:04 PM
Little Compton
, Rhode Island
Towing problem
Im just towing my 1972 Overlander 72 for the first time today. I ran into a problem. I was in front of my house about to back it into the driveway and the brakes on the trailer locked, I can not back this up. I drove a little way down the street checked the pigtail and all seems ok, the lights and blinkers etc, work. It just wont back up. What am I doing wrong or is there something I need to know? Thanks for any help.
Jim O'Connor
12-29-2014, 02:11 PM
1987 Avion 34W owner
Good Ol'
, USA
I assume the trailer has electric brakes? If so, could the connector be wired incorrectly so that when the tow vehicle is put in reverse, the brakes get energized? Otherwise, I would raise a wheel/tire and check for mechanical problems.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
12-29-2014, 02:13 PM
Briarcliff
Try unplugging the trailer pigtail from the tow vehicle........reverse lights maybe wired to brakes?
If that doesn't work, sounds as if there is a mechanical problem with the trailer brakes.
EDITED - beat to it by PaulNGina!
1966 T-27 Avion (Sold & missed)
2022 Escape 19
12-29-2014, 02:14 PM
Good Ol'
, USA
Great minds think alike!!
1987 Avion 34W
12-29-2014, 02:17 PM
Briarcliff
And another Avion owner even!
2022 Escape 19
12-30-2014, 07:16 AM
Little Compton
, Rhode Island
Unplugged
Hi,
Thanks for responses, I unplugged the pigtail and can get the trailer backed up. When I plug it back in the reverse brakes lock up. But at least Im able to back it into my driveway until I can get it solved. Any thoughts though? Maybe the pigtail is bad? Probably not its in good shape. Another wiring problem? Could they have just frozen up from lack of use?
12-30-2014, 07:28 AM
1965 17' Caravel
brooklyn park
brakes
make sure the emer. cable is seated properly, or the brake magnets will burn up; wiring can be corroded also! joe in MN
12-30-2014, 07:38 AM
Good Ol'
, USA
There is a wiring problem in the connectors. On the tow vehicle, the pin that is providing 12V that is supposed to turn on the back-up/reverse lights is getting directed to the pin on the trailer connector that is providing power to the brakes. I would assume that the brakes are not working at all when you are moving forward. Is this a 7-pin plug?
1987 Avion 34W
12-30-2014, 07:45 AM
Princeton
, New Jersey
First thought would be the Beakaway switch pin has come out and you have Full Power going to the breaks from the trailer battery.
If it was one break it could be mechanical but more than one it has to be electrical and if not the breakaway disconnect the umbilical cord and try again.
2004 Excursion 4x4
12-30-2014, 07:49 AM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings Jim!
Since this was your first tow with your Vintage Airstream, my suspicion is that your trailer's umbilical cord is wired to the earlier Airstream pattern for the seven pin connector -- or possibly a unique pattern used by a prior owner. A misplaced brake wire might be being energized by your backup lights when reverse is selected.
Good luck with your Airstream!
Kevin
12-30-2014, 07:51 AM
2000 19' Bambi
mt. Prospect
Unplug the umbilical cord. Then, there will be no signal to the brakes. Now you should be able to move the trailer.
When the cord is connected, and if it moves forward, but locks up only when backing up, then you may have a mechanical problem. Some drum brakes have an auto-adjust feature that tightens the adjuster when backing up, and yours may be doing this.
12-30-2014, 07:54 AM
2000 19' Bambi
mt. Prospect
What Kevin said - check the wiring. The backup lights are often marked as Auxiliary
12-30-2014, 07:59 AM
Moderator Emeritus
1964 26' Overlander
Anna
Greetings Jim!
In this type of situation, the wiring of the seven pin connector is the prime suspect. Airstream utilized a wiring pattern of its own unique design during the era of Vintage Airstreams. I suspect that you seven pin connector needs to be wired to today's standard -- I know that this was something that I had to do with my 78 Minuet before my first tow.
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
