Old 10-14-2007, 03:33 PM   #1
1968 26' Overlander
Ann Arbor , Michigan
Images: 11
Tow company vs. Tow Myself?
I am sure this question must have been asked before but I was unable to find it (newbie). Here is the deal. I have a trailer that I have just purchased...sitting since 79 I believe. I have been calling around to different tow companies and the going rate is about $600-$650 to tow 125 miles one way! This would be if everything was in rollable condition. For a flat-bed/lowboy it is 110 an hr...it is 2.5 hrs away from where I live. Would it be better to just spend the money on tires and brakes and tow it myslef?
It is a 68 overlander and I am having a devil of a time trying to find bias-ply tires in my area for a resonable price.
Thank You in advance for reading this post.
Aluminati is offline   Reply With Quote
Old 10-14-2007, 03:45 PM   #2
Road Ruler's Avatar
Images: 38
Radial tires would be the way to go as far as replacement of the tires.
Old 10-14-2007, 04:02 PM   #3
Make sure you check out the axles.
The following will help you to check them.
Dura Torque Axle
Any torsion axle trailer setting for 28 years will have failed rubber rods, which lowers the trailer, which causes it to bottom out when hitting bumps. That in turn, results in many other damages to several things.
Also, get all the exterior gaskets replaced asap, to keep the rain out.
Other repairs can take place later as long as you keep the inside dry.
Old 10-14-2007, 04:42 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Tow It Yourself??
WELCOME, YOUV'E COME TO THE RIGHT PLACE FOR ALL THINGS
AIRSTREAM
If you have the time and feel comfortable/confident in doing the
necesasary work, and if the tow vehicle is up to it, go for it. Better to spend
the bucks on the new toy!!!!
Start at the front, make sure the propane tanks are empty, inspect the hitch
Are there weight distribution bars and sway control, if not youv'e just spent
some of your savings. Your tires(radials) are already off, being mounted and
balanced on new, or carefully inspected wheels. Time to replace the brake
shoes, clean and inspect the drums, re-surface if needed, replace magnets if
necessary and inspect & re-pack wheel bearings, replace if in doubt.
While it's on jack stands, with the wheels off, time for some real FUN.
Plug er' in to the T.V., and start checking all the lights and brake power
supply, of course youv'e already got that brake controller installed.
These are all things your going to have to do before using the new rig.
We can all understand if this is more than you want to get involved with
125mi from home, some further tow shopping might be in order. (flatbed)
Then we have the FORUM....you will no doubt hear from some fellow
Michi-Streamr's who may be able to help out before the snow flies!!
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 10-14-2007, 07:45 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Welcome to the forums. You can expect answers to your questions all over the map, you know what they say about opinions. You will find a lot of good good info however.
My answer to your query, and many others, is it depends. Depends on how far you have to tow and over what quality roads, and how adventurous (some would say foolish) you are. Tires that old no doubt are rotten. Even if they don't look it. You have tandem axles if one blows and you go SLOW you will PROBABLY be OK bring a spare, and some axle grease for the road if you don't grease the axles first. Personally I wouldn't worry about empty propane tanks, but that's just me. Also depends on how much towing a fairly large trailer you've done. If you haven't I think it would be better to go pro or have the work done at a RV service provider first. I'm not sure if someone else mentioned it yet but a tow at anything other than SLOW speed without trailer brakes is asking for it. I'm sure there are other who hold to the opinion any tow of this size vehicle without brakes is a disaster waiting to happen. A 4-5000# trailer without brakes will push your TV in a panic stop and may very well jackknife.
What Can I Tow? doug1939 Tow Vehicles 9 06-16-2007 09:26 PM
What can we tow?? gnorris Tow Vehicles 9 05-04-2004 10:23 PM
Which to tow with? Windstar or F150 dmbcdn Tow Vehicles 20 11-11-2003 03:03 PM
Anyone TOW w/one of these?????????? Chitown AirStreamers 1965 Safari 1 05-13-2003 09:06 AM
What will I need to tow? dbmarshall Our Community 6 12-14-2002 07:37 AM
