Old 02-21-2015, 03:36 PM   #1
2018 25' Flying Cloud
Mission , Texas
Tow break-away switch testing?
Is there a way and/or is it necessary to test the break-away switch that activates the AS breaks if the camper comes loose from the TV.
Later: Just read some of the posts below & seems my questions are answered.......
ghamr is offline   Reply With Quote
Old 02-21-2015, 03:49 PM   #2
2007 22' International CCD
If you want to test breakaway, you absolutely MUST disconnect the umbilical to protect your brake control from reverse voltage.
On item two, if you pull it, yes, the brakes will lock, but only as long as your batteries have power. The brakes will run down the batteries rather quickly. Breakaway is an emergency switch that locks the AS brakes full on when it's pulled.
If you are looking for theft protection, run a nice heavy chain or cable lock between dual wheels, get a coupler lock, lock the safety chains to a deadman loop in your driveway, or park the AS indoors. A determined thief can get past all this stuff if they really want the AS. At that point your insurance is your last resort.
KE4GNK/AE
Old 02-21-2015, 03:54 PM   #3
1994 34' Excella
Warren , Manitoba
Easy to test!! Have trailer hooked up, with electrical connection DISCONECTED.
Pull out the cord with the pin attached. Get in TV and try to drive ahead. Your wheels on the trailer should turn slightly then lock up. If they do no, they need to have the brakes checked and or adjusted. Do not do this test with the electrical connected to your trailer, as you will have an expensive electrical problem. The break away switch is NOT to be used as a parking brake or theft deterrent. Hope this helps!! Good idea to check this fairly often. You must also have good battery power in the trailer for the break away brakes to work.
Don't forget to put the switch back in before trying to drive away after testing!!
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 02-21-2015, 05:35 PM   #4
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
FWIW, I inadvertently pulled my break away switch hopping over the hitch while the umbilical was plugged in and nothing got fried on the truck or trailer, so....?
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-21-2015, 05:40 PM   #5
1994 34' Excella
Warren , Manitoba
Not a problem, mojo, as long as you don't put the brakes on in the TV at the same time. Then you have 2 feeds to the brakes!!!! Reverse voltage !!! Bad!!!
WBCCI #7394
Old 02-22-2015, 10:40 AM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I don't' understand about unhooking the cord first,as far as 2 feeds , positive going to the brakes,it is fine as both are 12 volt.Far as checking the switch ,just pull the cable out and try to drive forward,....no magic to it...
Old 02-22-2015, 10:44 AM   #7
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
I do it his way seems to work. Jack up the trailer so the wheels on two sides spin. Spin the wheels, pull the pin, if they stop it works, if not something is amiss, usually a low or dead battery.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 02-22-2015, 10:48 AM   #8
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A valid test has the breakaway switch powered by the trailer battery only, because that's the way it will happen if it's really needed; the umbilical cable will come loose when the trailer breaks away. So if the trailer brakes don't work off the trailer battery only, they don't work at all in a breakaway situation.
As for reverse voltage, I haven't analysed it to see if that's true. I always test the breakaway switch before connecting the umbilical, so I haven't felt the need to analyze it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-22-2015, 10:50 AM   #9
1994 34' Excella
Warren , Manitoba
Do a google search on the topic. Everywhere they tell you NOT to leave the electrical connected when testing. Your trailer battery feeds the brakes when the switch is pulled on the breakaway. If the brake pedal is pressed, with the main wire harness connected to the trailer, you will be feeding the tralier brakes with a second feed. Everywhere it warns you not to do this, as damage will occur. I am NOT going to try it to find out what will happen. Might feed in series, thus 24V to brakes. Fried brakes???
WBCCI #7394
Old 02-22-2015, 12:09 PM   #10
Problem is that most modern brake controllers use a solid state switch to power the brakes. Feeding voltage into the umbilical brake line can cause damage to that part of the controller and render it useless. Unplug it first for protection. And, as mentioned, you want to be sure the trailer batteries will power the brakes properly as well.
KE4GNK/AE
Old 02-22-2015, 02:58 PM   #11
silver 67's Avatar
1967 30' Sovereign
Leavenworth , Kansas
Brake away switch
I have read that once you pull the pin you should not leave it out but a few minutes as it is sending a full12 volts to the brakes which can heat up and warp the hubs and other problems.
Beth and/or David
67 Sovereign, double bed, rear bath-"Moby"
2005 Dodge Ram 2500 Hemi, Quad Cab-"Ahab"
"Vintage trailer, vintage owners"
silver 67 is offline   Reply With Quote
Old 02-22-2015, 03:42 PM   #12
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
I hope you'll tell me that I'm not completely irresponsible. My cable to the brake controller tore some time back (don't remember how)...I never had it fixed, and the wheels to Daisy are turning fine. Advice/admonitions please (much prefer the former). jon
B00merang is offline   Reply With Quote
Old 02-22-2015, 04:15 PM   #13
The breakaway switch is triple-redundant safety equipment, after the hitch and safety chains, both of which would have to fail before the breakaway switch does its job. So you're probably taking only a very small risk, physically.
Legally, breakaway switches are required in most states for trailers that have trailer brakes. You would have to check the regulations of the state in which the trailer is registered to see if they're required for yours. So you may be taking a larger risk, legally. If you live in a state that requires annual vehicle inspections, and those inspections include trailers, then a damaged breakaway switch should show up during the inspection, and you'd have to get it fixed before you could pass the inspection.
WBCCI #1105
TAC LA-4
Old 02-22-2015, 04:21 PM   #14
B00merang's Avatar
Hailey , Idaho
thank you, Protagonist...that was my line of thinking. I'll get it fixed before this traveling season starts (Florida and Alaska). jon
break away switch Cochese Brakes & Brake Controllers 2 04-26-2010 07:45 PM
Break-away switch recommendation? transy416 Hitches, Couplers & Balls 15 11-22-2009 07:36 AM
Testing Break Away Switch Sundance Brakes & Brake Controllers 11 11-15-2007 04:02 PM
Break Away Switch and Lanyard Question RBolton Brakes & Brake Controllers 6 01-10-2007 02:10 PM
Break Away Brake Switch davespann Brakes & Brake Controllers 1 07-30-2003 08:22 PM
