Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 06-10-2002, 02:01 PM   #1
Rog0525
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
testing the elec brakes?
I have tested and repaired all the elec apparatus in my '60 Overlander but I do not have a tow vehicle and cannot test the elec brakes. Is there a method to test the brakes without taking it to an RV garage? I am fixing this ol gal up for resale but want to be sure that everything is safe and functional while keepin my cost to a minimum. I would not sell a vehicle of this sort with known safety flaws.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 06-10-2002, 11:15 PM   #2
FrankR
Profile:
There are several ways
To check electric brakes, some temporary supplies are required. Aside from just dragging the trailer down the road, static testing will check for braking action. To do a test, a battery must be placed at the tongue of the trailer, a 30 amp ampmeter, a 12volt dc test lite, and a couple number 12 gage test wires with aligator clips. The easy test...connect battery negative post to good frame ground or to trailer battery ground. Connect amp meter to trailer electric brake wire. Observe meter while making connection and note amps,.... should be about 15 amps. If amp reading is very low, one or more brake magnet coils are not working. To be assured all brakes are getting 12volts dc, use test lite at each wheel. Disconnect jumper from battery and remove meter. With a sngle wheel jacked off ground, have helper spin wheel and observe wheel stopping as power is applied to brake control wire..... Or just hook up to tow vehicle with correct brake controller......
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 06-11-2002, 02:14 PM   #3
Rog0525
Rog0525's Avatar
Images: 11
Thumbs up Thanks Frank
I printed out your your advice and will give it a try. I'm learning a lot from these forums and the helpful advice is much appreciated.
Rog
Old 06-11-2002, 04:02 PM   #4
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Ref: Elec. Brakes
I agree with everything FrankR says, no question abt it~!!
If I may say this, since it's an elec. system, why not connect the terminal to the battery thru a sw while standing by the wheels and, feel each one as you turn it on and off?? That would save a short drive if all you wanted to know if it's active on each wheel. Of course, this is a subject that's most often overlooked along with wheel bearings and, needs at least a bi-annual or 6000k tops check out. Great to run into you again FrankR~
ciao
AIR 807
53flyingcloud is offline   Reply With Quote
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 09:05 AM
Intermittant Brakes dinoburb Brakes & Brake Controllers 4 11-12-2003 09:00 AM
Trailer brakes won't lock-up? John Brakes & Brake Controllers 24 02-06-2003 01:22 PM
Heeeelp! My brakes have failed...any one had a similar experience? williamhenshall Airstream Motorhome Forums 9 07-12-2002 04:04 PM
