Old 07-14-2007, 12:44 PM   #1
Devils Lake , North Dakota
Question Testing Break Away Switch
Can I test the break away switch on my Argosy?? I know they are "cheap", but if I can put a meter on it and test the one thats there why spend the $25?
Sundance is offline   Reply With Quote
Old 07-14-2007, 01:54 PM   #2
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I think the easiest way is to be hitched up to your trailer, then:
1. Disconnect your 7-way umbilical (this will prevent damage to your brake controller)
2. Pull your brake pin. Note that this pin should never be out for long, so be ready to proceed with step 3 immediately.
3. Gently try to move your trailer. The wheels should be locked.
4. Go and put the brake pin back into the breakaway switch.
If the wheels did not lock, check to see if your trailer battery is connected (this is what powers the brakes when the pin is pulled).
There are several postings on this subject if you need better help than this.
Pat
pmclemore is offline   Reply With Quote
Old 07-14-2007, 01:59 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
If one person is placed near the axles and one pulls the breakaway switch, shouldn't the brakes start to hum? While this wouldn't detect effectiveness of the brakes, it should determine if they are getting power.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 07-14-2007, 02:18 PM   #4
1960 24' Tradewind
Riverside , California
Breakaway test
Put a test light to the non powered side of the switch and pull the pin, or pull the pin and put a compass close to the wheel, it will deflect to the drum because of the magnet, or the surest test is to jack up a wheel and try to spin the wheel with the pin pulled.
Zoom
ZoomZoom is offline   Reply With Quote
Old 08-02-2007, 04:01 PM   #5
1979 31' Excella 500
Battle Mountain , Nevada
Send a message via Yahoo to mikeandbecky
Testing break away
Whats the Worst that would happen, if for example, the pin had been removed from the switch for an extended period of time..( days...)? Would it create a " mystery power drain"... and also, would any damage come to the elec. brake system of the trailer or brakes?
mikeandbecky is offline   Reply With Quote
Old 08-02-2007, 04:07 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
If the brake system is in good condition, then all that would happen is that the batteries would go flat trying to keep the brakes applied. Inconvenience? Yes! Damage? Probably not.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 08-02-2007, 04:33 PM   #7
DO NOT leave a break away switch pin pulled for more than 5 minutes.
If left in the pulled mode long enough, it can burn up the magnets and detemper the axle spindles.
Old 08-02-2007, 04:40 PM   #8
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
We tested ours once. Sandwiches near a big truck stop, and decided to turn sharp and go fill up afterwards. Slight bind in the pull line, and zonk! We were stopped deader than a doornail. Boy, were we ever glad to discover that the pin can be reinserted!
Lynn
WBCCI 21043
Old 08-02-2007, 05:27 PM   #9
CanoeStream's Avatar
St. Cloud , Minnesota
pmclemore already said it -- do not do it while attached to the TV -- Prodigy controllers are known to fry!
5 meter Langford Nahanni
Old 08-02-2007, 06:29 PM   #10
OK. Well, I'll guess I'll find out this weekend ( when I have the time investigate further). Thanks!
Old 11-15-2007, 11:16 AM   #11
bobfowler's Avatar
1972 Argosy 20
Middletown , New Jersey
Images: 14
I know this is an old thread, but...
What the world needs is a breakaway switch that not only applis the trailer brakes, but also disconnects the line to the brake controller so as not to fry it when testing.
Bob Fowler
Some people are like Slinkies. They're really good for nothing, but they still bring a smile to your face when you push them down a flight of stairs.
TAC - NJ-007
bobfowler is offline   Reply With Quote
Old 11-15-2007, 04:02 PM   #12
SilverCottage's Avatar
2007 27' Safari FB SE
LONDON , ON
I know it is an inconvenience to send it back but there a lifetime warranty on Prodigy according to their web site:
Tekonsha
SilverCottage is offline   Reply With Quote
New battery selector switch FrankR Electrical - Systems, Generators, Batteries & Solar 6 02-08-2013 06:34 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
What the heck is that switch on the wall??? TRAPEZE Airstream Motorhome Forums 7 09-10-2002 04:05 AM
Spell Check is here... At least for testing! Andy R Forum Admin, News and Member Account Info 7 06-27-2002 12:45 AM
