Old 08-13-2004, 10:24 AM   #1
Tekonsha Commander Brake Controller
Any experiences with this particular controller? The tow vehicle I bought happens to already have this installed. No, I haven't used it yet. I'm looking for experiences/opinions on it. Initially I was planning on installing a Jordan, however since I bought this truck and the Commander is already installed I was just gonna leave it.
Here is some info on it:
http://www.marksrv.com/9010manual.htm
y5e06 is offline   Reply With Quote
Old 08-13-2004, 10:48 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
It's a pendulum type brake controller much like my previous Voyager.
The pendulum type controllers need to be leveled, but work ok. The prodigy uses electronic deceleration sensors to activate the brakes, which does not require leveling.
I now have the Prodigy, and would like to try the Jordan.
My prodigy works excellent while underway on the open road, but presents poor performance ( jerky brakes) while driving in traffic, especially any kind of stop and go.
If it works, then i would try it out, since it is already installed. Replacing it won't be very difficult, with all the wiring already done.
Uwe
www.area63productions.com
Old 08-13-2004, 01:26 PM   #3
I will try it first. If the wiring is the same at the controller, splicing in the Jordan should be real easy. If the commander works well then I'll use it, if not then I'll up grade. I want a good, reliable, well performing towing setup.
Old 08-13-2004, 03:30 PM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I used a Commander for 5 years prior to my current Jordan....as a matter of fact its sitting on a shelf in my garage today. I found it to be a good reliable unit and was pretty happy with it. I decided to go with a Jordan about four months after purchasing my '01 Safari. I didn't know what happy was until I used the Jordan for the first time. It makes all other older controllers pale in comparison. Even my dealer was surprised as to how good the Jordan felt when he did his test pull on my new Classic.
Jack
Jack Canavera
STL Mo.
AIR #56
Brake controller crapped out Chuck Brakes & Brake Controllers 5 06-21-2004 07:21 PM
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 06:47 AM
Brake controller hook-up Dimick Brakes & Brake Controllers 7 05-15-2003 08:57 PM
Brake Controller Hook-Up Dimick Brakes & Brake Controllers 6 03-09-2003 01:44 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
