Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 03-30-2008, 09:01 PM   #1
swinginping's Avatar
1989 34.5' Airstream 345
waynesboro , Virginia
Tag Axle brake controller questions..
wasnt gettin much of a repsonse on my older tag axle brake post in the motorhome section as it had been posted onto a good bit and started out with a different question but finally got some time today and went out and checked out the tag brakes.... had no power running back to brakes with the standard controller, so i hooked up the the wires to a tekonsha manual controller i used to have in my tv... its a new model only 1 year, voyager i think, a manual style and my green light was lit, and when i squeezed the thumb control it turned red, and i taped it in that spot and went back and i could hear my magnets on both sides making noise.... however they either weren't grabbing the hub or my pads are too worn... but they dont look to bad. If i hit the foot brake... my controller would turn red then the light would go out altogether.. and this would happen really really quick before the brake was even close to fully depressed.... anyone ever had this happen before??? I've never had any problems with electric brakes so im not exactly the best with them.... seems wierd i can use the thumb brake but not the foot brake... seems like a short somewhere but like i said i havent done much work with electric brakes.
1989 345LE
swinginping is offline   Reply With Quote
Picking up our first Airstream - Hitch & Brake Controller Questions palmsprings Hitches, Couplers & Balls 12 04-13-2006 07:14 PM
controller for tag axel brake lorcan Classic Motorhomes 5 07-01-2005 09:32 AM
Tag Axle Brake Parts swebster Mechanics Corner - Engines, Transmission & More... 5 10-12-2004 06:59 AM
what's the tag axle for? maznblu General Motorhome Topics 1 04-16-2004 07:54 PM
Tag Axle Brake Controller winner Brakes & Brake Controllers 4 06-30-2002 08:47 AM
