Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 06-29-2002, 07:52 AM   #1
winner
Dr Joe
winner's Avatar
Profile:  Central , South Carolina
Question Tag Axle Brake Controller
I have noticed that the green indicator light on the Tag Axle Brake Controller mounted on the left side of the Steering Column remains green even when the ignition switch is turned off, and the Kill switch for the coach batteries is off, and the engine battery is removed from the battery box. I am wondering if this is normal, or indication of a shot in the system. I have also noted that when the "Power" knob on the top of the controller is rotated, the light changes from green to red.
Dr Joe & Winn
Emeritus Airstreamers
KD8VD
winner is offline   Reply With Quote
Old 06-29-2002, 10:21 AM   #2
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Tag axle
Dr. Joe,
You might resend this post in the motorhome section. As a trailer owner I am really confused.
But then grass confusses me too.
>>>>>>>>>>>>>>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 06-29-2002, 10:42 PM   #3
83Excella
83Excella's Avatar
Profile:
Brake controller
I have a Tekonsha controller and the single green light indicates a few things, when it is on and the engine is off it tells me the pigtail on the trailer is connected to the truck and trailer brakes are usable, but if I disconnect the pigtail the light goes off. The green light will also turn red as I apply brakes or apply via the manual slide switch, the brightness of the red is adjustable by the gain switch which is applying more brakes as the light gets redder. I believe the controller gets its power from the tow vehicle. If you pulled the battery and the light is on its telling you something is wrong I would think.
John
83Excella is offline   Reply With Quote
Old 06-30-2002, 08:00 AM   #4
winner
Dr Joe
winner's Avatar
Misplaced thread
Based on responses, I obviously should have posted this thread in the Motor Home Forum - although it refers to the steering column in the text. If I knew how to move it I wouild, thanks for the comments.
Dr Joe & Winn
KD8VD
Old 06-30-2002, 09:47 AM   #5
83Excella
83Excella's Avatar
Profile:
brake controller
I thought you were talking about a trailer, you did'nt specify.
John
Hensley Brake Controller $427 New markjoandall Brakes & Brake Controllers 2 11-19-2003 07:47 AM
Tag Axle Brakes cooperhawk General Motorhome Topics 1 06-23-2003 01:48 PM
Brake controller hook-up Dimick Brakes & Brake Controllers 7 05-15-2003 09:57 PM
Brake Controller Hook-Up Dimick Brakes & Brake Controllers 6 03-09-2003 02:44 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 02:05 PM
