Old 06-17-2007, 05:12 PM   #1
Whirl with Earl
aprimosch's Avatar
1958 22' Flying Cloud
Ventura , California
Images: 18
Stromburg Hydraulic Brake Actuator
Hello.
I have a few questions about a Stromburg Hydrolic Brake Actuator that is on my 1958 22-ft. Flying Cloud. I am in the process of rebuilding the brakes. The drums and baking plates were no surprise, but I am not sure how this hydrolic actuator even works. Also, how does this tie into the braking system while the trailer is moving. Does anyone have pictures of their working brake setup, or possibly of a rebuild in process. Also does anyone have the complete front set up of this year including the propain tanks, trailerjack, etc... And what the heck are those two little hooks on the frame rails?
ID:	39438   Click image for larger version
ID:	39440   Click image for larger version
Wherever you go, you are.
aprimosch is offline   Reply With Quote
Old 06-17-2007, 05:20 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The two hooks are for the WD bars, and the little ball on the curbside is for the friction sway control.
Old 06-17-2007, 06:01 PM   #3
Images: 14
Look at this referenced thread
http://www.airforums.com/forums/f439...ked-29397.html
I have one of these also but it was on a dual axle trailer and one axle was hydraulic and one electric brakes. So the break-away and maybe parking brake function made sense. But on a single axle ???
bjond is offline   Reply With Quote
Old 06-19-2007, 10:46 AM   #4
Whirl with Earl
aprimosch's Avatar
Images: 18
Thank you for all of your timely research.
That is interesting to learn that my single axle airstream never was hooked up to a car's brake system. It was only hooked up to the electrical to run the taillights and running lights. The hydrolic brake was only used as a parking/ breakaway brake. So technically, I do not have to have brakes on my single-axle trailer for towing. I can easily use wedged-blocks under the tires to prevent rolling when parked. -And of course, drive slowly down steep grades to prevent jack-knifing. Any other thoughts?
I never did find out what those hooks were used for on the tongue. Unless of course, overlander63 is serious. If so, what is he talking about?
Cheers.
Old 06-19-2007, 01:32 PM   #5
Cheers.
Overlander63 is correct.
The Stromberg brake system was outlawed a little over 30 years ago.
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 9 07-12-2014 07:41 AM
Banks exhaust brake for Dodge Ram wflorencejr On The Road... 9 10-15-2005 08:26 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
Which brake controller? Andy R Brakes & Brake Controllers 2 03-06-2002 10:11 AM
