Old 05-27-2015, 08:16 AM   #1
steve0white's Avatar
1976 Argosy 28
Grand Rapids , Michigan
Stripped lug threads
Hello,
I have a 28' Argosy Center Bath. Last year I had someone else repack the bearings and this year I did it my self. While repacking a few issues cropped up. First I had to replace all of the bearings since they were pitted and discolored. Next, I noticed a couple of the bolt holes for the lug bolts were stripped. I ran a thread chaser through the holes, but one thread was damaged beyond repair (I re-tapped with no luck). It seems a waste to buy a whole new drum to replace it. It's a 10" x 2-1/4" 6 hole on 5-1/2".
Has anyone used helicoils or time serts to repair these threads? Or what about drilling them out and inserting studs? I don't have much in terms of a machine shop so it wouldn't be feasible to drill out a new hole pattern.
I called a couple local places and they didn't have anything in stock and I called a local mechanic and he didn't have the tools to do it. For the time serts it is more or less the same price as the getting two new hubs (w/ studs) instead of repairing what I have.
Any recommendations?
Thanks.
steve0white is offline   Reply With Quote
Old 05-27-2015, 08:30 AM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
New hubs are easily available. If the cost is close (considering the value of your time), I'd suggest that you get new hubs. Recycle the old ones to minimize the waste.
Old 05-27-2015, 08:59 AM   #3
Kevin245's Avatar
I'd recommend new drums rather than trying to fix bad threads with studs, inserts, or re-tapping. The cost drums is in line with the effort and money you'll likely expend going the repair route, not to mention the comfort of knowing the work was done correctly.
Eleanor Roosevelt
Old 05-27-2015, 09:30 AM   #4
1981 31' Excella II
New Market , Alabama
99% of lug bolt and stud problems are from improper use of impact wrenches.
You can put a helicoil in there but the kit might cost as much as a new drum. Most of the time you need an oddball drill bit and oddball tap to install them. The inserts themselves are only about $1 each but all the bits to make it work might cost $100.
Perry
Old 05-27-2015, 09:40 AM   #5
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You can drill and put inserts in for not as much as you think if you do it yourself new hubs are about 115$ each
Old 05-27-2015, 09:41 AM   #6
1976 Argosy 28
Thanks for the responses. Looks like I'll just buy some new ones.
Self tapping floor screws, stripped threads polarlyse Repairing/Replacing Floor &/or Frame 6 05-14-2011 01:10 PM
lug nuts or lug bolts Mbirdshooter Wheels, Hubs & Bearings 3 07-20-2010 02:00 PM
Lug nuts vs. lug bolts dorfgog Wheels, Hubs & Bearings 9 04-19-2010 09:41 PM
5 lug vs 10 lug wheels rollin home Wheels, Hubs & Bearings 0 08-03-2009 02:23 PM
Stripped lug bolt holes chris's 67 Wheels, Hubs & Bearings 3 03-30-2008 05:27 PM
