Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 12-09-2006, 11:44 PM   #1
wayne.yl's Avatar
Profile:  1977 31' Sovereign
1992 34' Excella
Salem , Oregon
Strange noise coming from the wheels
I have this strange noise, kinda like metal chirping or clacking when I get the trailer going 15mph and faster. I cannot figure out what the noise is or even exactly where it is coming from. after riding my kids bike along side the trailer while my neighbor drove, I have concluded that the noise is coming from the wheels. The only thing I can think is that the disc brakes pads are rattling as they are loose, or it could be the bearings going out or possibly it could be the little hub inserts on the the aluminum wheels. Honestly, I am just guessing and am hoping someone might shed some light on the mystery. I recently repacked the bearings on the trailer this past summer and followed the instructions on this forum to the tee. I am hoping this noise is not a result of me doing something wrong but at this point I am only guessing. Any thoughts?
wayne
wayne.yl is offline   Reply With Quote
Old 12-10-2006, 01:03 AM   #2
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
In my past life I worked in the auto repair business. It is very common for wheel covers and wheel trim to make clicking, and other noises. IMO it would be less likely for the disk brakes to be making noise, usually they will click when applying brakes after changing directions, ie forward or backward. This would cause the pad to shift in the direction of the wheel rotation.
Get a rubber mallett and bang around on the wheel, you can usually duplicate the noise and pinpoint it.
Dave
Fyrzowt is offline   Reply With Quote
Old 12-10-2006, 02:33 AM   #3
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
Could be the wheel covers but all the clicking and clackings I've had in vehicles I've driven in 52 years have been bad bearings.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
Our Rig
Sept 2009
1966 Trade Wind
455 cid
Old 12-10-2006, 06:32 AM   #4
McHenry , Illinois
The 77's that came with disk brakes usually came with Mag wheels with no hub caps, so that is out. The 40 year old disk brakes usually make noise and wear unevenly. It is likely one of the brake shoes has one end of one pad worn out. The only way I got mine to wear evenly was to, rotate them half way through their life. Andy has new sets but he charges alot. You can buy them direct for alot less if you can locate the supplier.
dwightdi is online now   Reply With Quote
Old 12-10-2006, 06:46 AM   #5
boatdoc's Avatar
Profile:  1973 Argosy 26
Norristown , Pennsylvania
Arrow Strange noise from wheels.
wayne
Hi Wayne; Remove wheel caps and repeat your drive test. Second, jack up one side of the trailer and spin the wheels by hand, any growling noise while wheel is rotating indicates problem with bearings which is magnified under load. Do not mistake brake pad drag for the low growl of the bearing. Compare the sound of each wheel against rest of them. Loose lug nut may be possibility. Check for cracked welds on inside of rims. Check torque on axle retaining bolts to frame, by trying to turn bolt heads exposed behind the wheels. If they turn easy, they are loose. Check shock absorber bushings for free play. Finally be sure your trailer plug is clean and dry at the TV.
Hope you uncover the mystery. Thanks "Boatdoc"
boatdoc is offline   Reply With Quote
Old 12-10-2006, 09:21 AM   #6
Melody Ranch's Avatar
Profile:  1966 17' Caravel
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
Noises?
I'd vote for check the bearings...its a good time of the year to grease 'em up anyway.
I really subscribe to the "get a bigger hammer" school of thought too.
Apply it to all problems.
Old 12-11-2006, 02:04 AM   #7
wayne.yl's Avatar
1992 34' Excella
Salem , Oregon
Hey all,
thanks for the advice. I am going to start eliminating the possibilities as boatdoc suggests. I will keep you posted. I was hoping to get to it today but the Christmas tree and lights had to come first. My 10 year old daughter was driving the day's agenda. Oh well.
Wayne
Old 12-11-2006, 02:12 AM   #8
FreshAir's Avatar
Earlier in the 20th century mischievious pranksters would put rocks in peoples hub caps. That silliness died out with full wheel covers as it did not have the same effect. If you have hub caps on your AS and have old pranksters that live near you.......
Neil.
FreshAir #12407
Avatar;
Our Rig
Sept 2009
1966 Trade Wind
455 cid
Old 12-11-2006, 02:14 AM   #9
wayne.yl's Avatar
1992 34' Excella
Salem , Oregon
Boatdoc, I am just curious about how the trailer plug could be a factor in this noise mystery. One reason is that I live in Oregon where it rains alot in the winter and having a dry trailer plug is difficult. we are wet most of the time up here. Just curious.
thanks for your input.
wayne
Old 12-11-2006, 04:40 AM   #10
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
wayne
Wayne,
You can get single strands of wire bridging each other that will cause partial/intermittent application of the brakes. I have actually had a similar problem that was caused by a dual filament bulb that had vibrated so much in it's socket that the lead on the leads was bridging the terminals in the socket...took a while to find that one.
Aaron
WBCCI #2449 AIR #2495
Old 12-11-2006, 11:34 AM   #11
Foiled Again's Avatar
Virginia Beach , Virginia
Dry Plug (Hijack)
wayne
Glad Press & Seal - wrap it around your plug and seal tightly when you aren't towing. I keep a roll in "Big Dawg" my tow vehicle.
ANOTHER item from the "Girl's Tool Kit" that's real handy.
Paula Ford
Old 12-11-2006, 12:20 PM   #12
Commercial Vendor
Profile:  Corona , California
wayne
Several different things can contribute to those noises.
1. Worn clevis pins.
2. Worn bushings in the calipers.
3. Worn or loose studs on the caliper brackets.
4. Warped rotors.
5. Lastly, a defective bearing.
You must remove the wheels to thoroughly inspect each disc brake assembly.
You can rotate each rotor by hand, to find which one is causing the noise.
They should all be absolutely silent.
Depending on what you find, we have replacement parts for the original Airstream disc brake system. We also overhaul the calipers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-12-2006, 05:30 AM   #13
boatdoc's Avatar
Arrow Noise in wheels
wayne
Hey Wayne; I was sure you would know why I said it. A wet shorted connection in your plug can momentarily send partial current to your brakes causing the solenoids to clack. Thanks "Boatdoc"
Old 09-12-2007, 09:22 PM   #14
wayne.yl's Avatar
1992 34' Excella
Salem , Oregon
Strange noise is still there
wayne
I still have this noise I described several months ago and was hoping it would go away when I replaced the bearings several days ago. I have narrowed it down to the the calipers. I raised the trailer and spun each wheel. I found that there is some very slight play in the wheels and this results in a rattle at the caliber They rattle on the mounting posts very slightly but enough to make the noise. My question is whether there should be any play in the wheels at all? Have I not tightened the bearing nut down enough?
thanks
wayne
Noise dry camping ChrisAich 2003 International CCD 24 07-28-2003 07:58 AM
Univolt Low Buzzing Noise rjones1138 Electrical - Systems, Generators, Batteries & Solar 23 07-16-2003 07:23 AM
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 2 06-22-2002 05:41 PM
Best wheels & Tires... Andy R Wheels 4 04-15-2002 11:41 AM
