Old 07-08-2012, 08:35 PM   #15
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Brakes
My 7 pin connector cable has some damage, looks like it probably got pinched pretty good sometime in it's life, and I wonder if that could possibly be the culprit? I need to get an amp meter to test the brakes, but wondered if installing a new connector cable might be in order, and how hard is it?
Rod
rbs is offline   Reply With Quote
Old 07-08-2012, 08:45 PM   #16
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
Rod
If you've got a partially broken wire, for sure it could interfere with the system. It's fairly cheap to replace so might be a good place to start.
Friday is offline   Reply With Quote
Old 07-09-2012, 07:36 AM   #17
HowieE's Avatar
Princeton , New Jersey
Images: 12
The separation between the connections in the 7 pin connecter is VERY SMALL. Almost any damage from compression could cause a short between 2 wires.
If you have any question open the plug and check.
When I replace one I like to make the connection with the screws and then solder them to prevent vibration form causing a problem.
2004 Excursion 4x4
