Old 07-10-2006, 09:42 PM   #1
ft collins , Colorado
Step on brakes and trailer lights turn...OFF
Anyone seen this before?
Two nights ago I changed out a couple of clearance lights. Everything working great. Tonight I turned on the lights in the vehicle to show my wife the lights and they are on but it looks like a brown out. They are getting juce, just not enough. Then I notice the brake lights are on constantly on the trailer. When I step on the brake they then turn OFF. However if the lights on the vehicle are off the brake lights light up just fine.... Any electrical whizes out there? Thanks for your help.
Bridger
bridger is offline   Reply With Quote
Old 07-10-2006, 10:20 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Looks like a ground loop. Revisit the clearance lights and any other fixtures you worked on.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 07-10-2006, 10:23 PM   #3
TIMEMACHINE's Avatar
Huntington Beach , California
My guess
Well, I am no electrical wiz, but, your clearance lights and your brake lights require power through your TV 7 pin connector. Your interior lights are internal wired and should not be in line with either brake or clearance lamps.
I would recheck the clearance lamps you worked on and the 7 pin connector. It is possible that some kind of short discharged your AS and TV batteries, which of course would make your AS interior lights very dim if not off. If your AS battery was depleted (drained), then it is possible that the application of the brake sends more current to the brake lights and thus dropping the current to the AS turing the lights off.
Just my guess! Maybe an expert knows the answer for sure.
John
TIMEMACHINE is offline   Reply With Quote
Old 07-10-2006, 11:19 PM   #4
Can you tell me more about the ground loop? Can I tell with a volt meter?
Bridger
Old 07-11-2006, 05:20 AM   #5
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
This is a job that requires some electrical knowledge. You either have to learn it yourself or find someone to help you out. It would be better to do the latter. Have an electrician friend help you out.
Old 07-11-2006, 05:28 AM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You may have a bad ground from the tow vehicle to the trailer. Your clearance lights may be using all the ground the bad connection can carry, and when you step on the brakes, it overloads the ground and shuts all the lights off. Check the 7 pin connector, then the ground wire on both the trailer and the tow vehicle.
Old 07-11-2006, 08:02 AM   #7
Okay so this morning I went out and connected the trailer to the hitch and Everything works Great! Why would connecting the trailer to the hitch do anything? Does it complete the ground?
Old 07-11-2006, 08:16 AM   #8
2006 30' Classic
Farmington , New Mexico
Images: 14
Yes it is but it shouldn't be. The ground circuit for the trailer comes through the wiring plug connector. One of the 7 wires is ground for trailer and truck. It's obvious this circuit is open. Keep in mind the poor ground { throught the trailer ball} to the lights is also the POOR ground for the trailer BRAKES !!!!! The brakes require more current than do the lights and with grease or rust at the hitch connection you are in danger of having trailer brake failure
pieman
Mike Lewis is offline   Reply With Quote
Old 07-11-2006, 11:57 AM   #9
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
This one is EASY. Just as Mike Lewis said, there is a problem with your seven wire connector and it is either in your tow vehicle or your trailer. You have a loose or mostly broken negative ground wire. First, take your 7 pin plug, the one attached to the trailer and take it apart. It's easy, a couple of screws and the cover comes off. Look for a wire to have pulled loose from the screw terminals in there, especially I believe a white one. Replace any that are loose. Look for broken ones, repair those as well. Did this fix it?
If not, get a multimeter, with a continuity tester built in; I like the ones that give a tone when a ciruit is made. You can get one at Home depot for about $15. Look up the pin placement for the connector, there's a website at Mark's RV that has it. Turn your mulitmeter to continuity and then poke or clip one wire onto your bumper(actually, it must be metal, I guess not too many metal bumpers anymore!) of your car and then poke the other one in the negative ground recepticle on your 7-pin connector. Should have continuity. If not, the problem is in your car. If this works, then check your trailer. That should be the prolem. Follow the negative ground from the plug, to the access panel on the underside of the trailer, should be a removable panel underneath, up front, by where the A-frame meets the body. Follow the wires until you find a broken one.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 07-11-2006, 09:32 PM   #10
1960 24' Tradewind
santa barbara , California
Hello bridger,
electricity will find the quickes path to ground .In your trailers case your
plug ground somewhere is missing as has been posted .A poor ground ,corrosion or loose connection will cause dim lights ,such as if your
car headlights ,older ones these days with the standard 3 prong plug,
is dim when the headlights are on ,as we have all seen one time or another,
you wiggle the plug and then the headlight goes bright .The ground wire is faulty . On trailers those poor grounds cause the electricity to travel
the path of least resistance ,as in your kooky operation of the brake lights and running lights .Get a solid connection as when you hitched up .all
returned to normal ,the lighting ,brake lights all suddenly work right.So
as everyone has said here ,locate the faulty ground ,be careful on these
types of problems ,because its easy to get off track ,replacing bulbs and
stuff .Dim lighting ,bad ground and other gremlins related to it.
Scott
scottanlily is offline   Reply With Quote
Grabbing Brakes 74Tradewind Brakes & Brake Controllers 15 08-05-2004 05:26 PM
ABS and Hydralic trailer brakes rschulz Brakes & Brake Controllers 1 04-17-2004 03:15 PM
Brakes/Univolt Rob Brakes & Brake Controllers 9 10-22-2002 05:50 AM
Did I ruin my truck's brakes?? Chuck Brakes & Brake Controllers 13 10-14-2002 09:03 AM
problem with Brakes jazzbone Brakes & Brake Controllers 33 08-23-2002 07:05 AM
