Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 06-10-2002, 05:18 PM   #1
74Tradewind
74Tradewind's Avatar
Profile:
Source for brake parts?
Where can I get brake drums for my A/S? Also can anyone tell me what the backing plate and shoes brand is. Hays? It seems my drums are egg shaped, the magnets are worn completely down as well as the shoes. I'm glad I looked before going on vacation this summer.
Oh well, it's only money.
74Tradewind is offline   Reply With Quote
Old 06-10-2002, 07:27 PM   #2
53flyingcloud
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
1964 19' Globetrotter
1953 21' Flying Cloud
Amherst , New Hampshire
Brakes
Let see if is this ans helps. Last July, I was visiting the A/S factory store and, they had the complete brake assy for something like 89$. All you had to do was pull the old ones off and, then install the new brake assy. As always, since you've got the wheels off at this point.. I'd go for repacking the wheel bearings grease as well. The only reason I mention this: I saw what happened to a nice couple's rear skin panel when the wheel locked up and, then damaged the skin when the wheel tore off. Ouch~~!
Their number is: 1-877-596=6505 or 1-937-596-6111 during business hours.
Hope this helps.
ciao
AIR 807
53flyingcloud is offline   Reply With Quote
Old 06-10-2002, 07:46 PM   #3
74Tradewind
Profile:
Factory Store???
Vern,
Where is a factory store located near Ventura California? I need the brake drum and the brake pads and the springs.
Old 06-10-2002, 07:49 PM   #4
53flyingcloud
brakes
As you're in CA., the only place that I know of you might try is Inlandrv.com
AIR 807
Old 06-10-2002, 08:08 PM   #5
74Tradewind
Profile:
Inland RV
Thanks, I tried Inland RV today via the phone. The girl answering said she did not know what was going on and she would have someone call me. I left my number and am still waiting for that call. I tried their email route last time and still have not received an answer. I'm not trying to be critial but......
I can't be the first one to need brake drums. I have searched the internet but to no avail.
Ciao, Brian
Old 06-10-2002, 09:20 PM   #6
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
I posted a reply to your other post in the Parts Forum.
http://www.airforums.com/forum...=&threadid=686
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 06-11-2002, 11:08 AM   #7
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Brian. I was out of town, and have a new girl answering the phones.
Hopefully, the suggestions I gave you on the phone, will be beneficial, and save you some money as well.
Turning drums, done properly, are very serviceable.
However, some machine shops can only turn the drum, and not the armature plate.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 06-11-2002, 12:04 PM   #8
74Tradewind
Profile:
Mea Culpa
Thanks for the call Andy!!! I will look into getting the drums turned locally. The new backing plates with all the new parts installed looks to be the way to go also. Thanks for you patience.
Brian
Old 06-11-2002, 01:13 PM   #9
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
Brake parts and hardware
Brian,
I found a Dexter dealer locally(Dexter is a wholesaler of truck and trailer parts) in Phoenix that supplied me with brake hardware and wheelbearings. The name of the company was Auto Safety House. They were very friendly, helpful, and inexpensive vs: a regular parts store. The parts I got were rated for the job and they did have brake drums however I did not need drums.
If you are interested find a Dexter dealer locally. (you can go on the net at Dexter.com) Or you contact Auto Safety House @ autosafetyhouse.com and get their 800#.
>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 06-11-2002, 05:26 PM   #10
BobbyW
BobbyW's Avatar
Houston , Texas
Here is a little Photo Montage of original versus new. All parts were purchased from a commercial trailer parts house in Houston,TX at excellent pricing. All parts are OEM to Airstream.
OEM Gabrial shocks came from BobJones RV for $25.00 each. Drums were turned and outside painted with high- temp brake paint. New bearings and seals were also installed. Check your Yellow-Pages.
Sure was fun going from rust-crusty to all new and shiny.
-BobbyWright
-BobbyW AIR# 123
-Red Green
Parts source for four position light switch overlander76 Electrical - Systems, Generators, Batteries & Solar 6 11-16-2003 09:24 PM
New Furnace Needed 74SovereignInt. Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-24-2002 01:03 AM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 09:42 AM
