Old 07-30-2010, 07:49 PM   #1
1960 24' Tradewind
Janesville , Iowa
Smoking Brakes, Need Help
Hey Folks,
My family and I are planing to leave tomorrow morning for NC from IA. We drove apx. 20 miles to stay with my folks and when we got here the wheels were smoking. I have just gotten our 1960 tradewind back together with new Dexter backing plates, shocks, tires, repacked bearings, and new seals. When I installed the new "self adjusting brakes" they seemed to just lightly touch the hubs so I thought they were good. We do have the trailer loaded with household things as we are moving and it weighed in at 3900 lbs. Is this the problem. Was there more adjustment required. How do I know the brakes are adjusted properly. Is 3900 lbs to much weight. Thanks for your help.
badger is offline   Reply With Quote
Old 07-30-2010, 07:59 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Is there a right and left for those self adjusting brakes? If so, do you have them on the correct sides?
I know that on the older cars with self adjusting brakes, they adjusted when backing, so if assembled incorrectly, they would tighten up when applied moving forward.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 07-30-2010, 08:13 PM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
There is the possibility, also, that the brake wire in the 7 connector plug had been incorrectly wired to the trailer plug. The Blue wire is usually the cause. Check this too.
Old 07-30-2010, 08:16 PM   #4
r carl's Avatar
Lin , Ne
Start by jacking up the wheels to see if they spin freely. If they are locked you will have to back off the adjusters to get the brake drums off.
Old 07-30-2010, 09:00 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I could be wrong, but I'll betcha a nickle you have the new backing plates switched side to side.
The adjusting rod or cable, which ever they use, should go to the rear shoe.
Old 07-31-2010, 05:12 AM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The easiest way, for me at least, is that the actuating arm always faces forward on the trailer - highlighted in red here.....
Self-Adjustment Note: Nev-R-Adjust™ brakes will self adjust after a few stops. To burnish the new brakes in, apply the brakes 20 to 30 times from an initial speed of 40 mph slowing the vehicle to 20 mph. Allow the brake to cool before starting the next brake application. Burnishing takes away the high lining spots, high magnet spots and machining marks on the drum surface.
Old 07-31-2010, 08:07 AM   #7
1960 24' Tradewind
Janesville , Iowa
Gentlemen, Thanks for your advice. Mr. Foster I believe I owe you a nickle.
Old 07-31-2010, 10:16 AM   #8
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
badger
Forget the nickle. Hope you didn't ruin your new brake shoes.
Just glad to be of some help.
Old 07-31-2010, 03:53 PM   #9
funkill's Avatar
reno , NV
Images: 27
Yikes --- but I feel better as I found I made the same mistake. I swapped the backing plates to the right sides and haven't found any damage done. Hope you are as lucky!
Laura
funkill is offline   Reply With Quote
I quit Smoking RichardT Off Topic Forum 404 01-27-2015 09:54 PM
what's smoking? Valentine/09 Lights - Interior & Exterior 3 09-16-2009 10:58 AM
smoking power cord boondockdad Electrical - Systems, Generators, Batteries & Solar 10 07-02-2008 06:34 AM
No Smoking at AIR Forums CanoeStream Fun & Games 31 04-02-2008 10:31 PM
Diesel Smoking JodynJeep Tow Vehicles 6 10-15-2003 02:24 PM
