Old 08-23-2017, 12:14 PM   #1
2011 22' Sport
Portland , Oregon
Should the brakes be able to lockup?
I tried to look for any threads on this subject but didn't have any luck, so apologies if there is a thread that I missed. I have a 2011 Sport 22FB, being that this is a 4500# trailer with a single axle there is a lot more weight on the 2 brand new tires than most trailers...so perhaps that is contributing to the fact that I cannot get the brakes to lockup as a reference point for adjusting braking force on the controller.
I had the bearings serviced and they stated the brakes looked "fine", when they could have tried to sell me new brakes instead. I don't know how many miles are on the trailer for sure since purchased used, but it wasn't ever used by full timers...just summer weekend getaways primarily within the states of WA and OR, so I wouldn't expect there to be significant brake wear.
TIA!
Xipper is offline   Reply With Quote
Old 08-23-2017, 12:26 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Depends on what road surface you are attempting to lock the brakes.
Generally most controllers suggest a hard packed gravel or dirt road and while driving at 25 MPH manually applying the brakes until they just do not lock. That is the adjustment point that will insure the max. braking force without the potential of the trailer braking free in a skid on a wet road.
2004 Excursion 4x4
Old 08-23-2017, 12:27 PM   #3
dznf0g's Avatar
Oswego , Illinois
They should lock with healthy controller and wiring. I'd start with a good adjustment check on the shoes, then look for amperage at each wheel. Electrical deficiency could be anywhere, most commonly at the connection to tv, followed by broken or chafed wiring to the hubs.
-Rich-
Old 08-23-2017, 12:30 PM   #4
Long Island , New York
We also have a single axle [FC20] and have wondered about this. Even had the Ford dealer check out the tow vehicle's brake controller recently -- normal electrical readings on their computer.
In our old 25' AS, with 4 wheels, we could not get the tires to lock up on pavement, but could do so if there was a little sand on the pavement. Also on gravel roads, no prob in locking up.
Ditto for the new FC20 -- will not lock up on dry pavement, but will do so if the pavement has some sand on it.
We have a service appt. for the AS coming up, with an experienced AS mechanic, so we will get further feedback.
Looking forward to other replies from more experienced AS owners.
Cheers,
Peter
PS -- Thanks Rich for the electrical draw feedback, and HowieE.
Old 08-23-2017, 12:31 PM   #5
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
For what it's worth, mine don't seem to lock up either - they did on a previous non-AS trailer I owned, but it was about half the weight of my AS so perhaps that is why.
Not too long ago, I completely renewed the brakes - new backing plates, magnets, etc. I even renewed the trailer ground connections which looked a little corroded, just in case that might have some relevance.
I measured the current flowing in the blue brake wire when under full brake application from the truck, and it was right up where it should be I believe - 12+ amps.
With all this done, I figured for sure the brakes would now lock up. Well, they seem much more effective than they were before , but still, on slow speed full braking tests on asphalt still do not lock the wheels, so perhaps it is nt to be expected.
I did this test right after installing the new brakes. I did not change the drums as they appeared ok.
Perhaps after about a years use, the new shoes have bedded in more now (they do seem quite effective) and if I repeat the test, they will now lock - I'll try it again next tme we are out.
Incidentally, I do find I need to drive the truck with the gain control on the built in brake controller cranked pretty much right the way up. Had I done that with our previous trcuk and SOB trailer, I would have been constantly locking up the wheels on slow arund town driving!
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Wingeezer is online now   Reply With Quote
Old 08-23-2017, 12:47 PM   #6
dznf0g's Avatar
Oswego , Illinois
I'm perplexed. I have never had a trailer that didn't lock up. In fact, with drums, I always felt they were too susceptible to locking when set to a good normal stop feel. As a side note my AS discs are very predictable and will lock up solid, smoke the tires, when set too high. That's another story....
-Rich-
Old 08-23-2017, 01:02 PM   #7
dmbecke's Avatar
Des Peres , Missouri
My will lock up and stop the truck when I apply the manual control
dmbecke is offline   Reply With Quote
Old 08-23-2017, 01:37 PM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I can smoke all 6 on mine with disc brakes. Once I got my prodigy 3 controller set, I haven't adjusted it in years.
I have it biased slightly hotter on the trailer side to help avoid a jack knife situation.
Old 08-23-2017, 05:21 PM   #9
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Xipper,
Lots of good advice have been offered, my turn to stir the pot.
As you examine and troubleshoot get an IR temp gun and add it to your kit.
Use the temp gun, read temps in same location on drum, hub and even tires.
No clue what drum temps should be but braking makes heat, no heat means no brakes. Uneven readings, one brake is lazy.
Great toolbox addition helps all kinds of thermal troubleshooting and even checking a griddle temp for pancakes.
Get to know your brakes.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-23-2017, 05:30 PM   #10
Half a Rivet Short
Carlisle , Pennsylvania
Hi
In general brakes that lock up are not a good thing. You loose directional control when this happens. Modern trailer brake controllers have all sorts of weird stuff in them to reduce the chances of this happening. How you get this or that controller to apply "full brakes" can be a bit hard to work out ....
uncle_bob is online now   Reply With Quote
Old 08-23-2017, 05:37 PM   #11
Bob do you know if modern brake controllers interact with the brake circuits they are controlling, in the sense that the controllers "know" whether the brakes are locking up? If so, the brake controller could reduce the electrical signal being sent to the brakes to prevent lock-up?
If not the above, to what "weird stuff" do you refer?
Peter
Old 08-23-2017, 06:59 PM   #12
Half a Rivet Short
Peter
Hi
I doubt there is much they can do to sense lockup with normal brakes. Most of what they seem to be doing is varying brake force with several factors:
1) Some sort of "gain" setting to modify the whole process
2) Varying the force depending on how fast the vehicle is going
3) Limiting the maximum force applied (either deliberately or through poor design)
4) Non-linearly mapping the foot pedal to the trailer brakes
They may be doing other things. You would have to dig a bit into each controller to see what it does or does not do.
Old 08-23-2017, 07:30 PM   #13
2011 22' Sport
Portland , Oregon
I've been attempting to calibrate the brakes on my Prodigy RF, it states to set the gain to the point they lockup on dry pavement at 25mph. I'll try to find an area that has reduced friction to see if they lockup, just not as easy to do until I am at a camping destination. The brakes do work, I just wasn't sure if I should leave the gain at "12" or just adjust them to the point they seem to be in balance with the TV and not that the TT brakes are working too hard to slow the TV. I'm sure those drums would overheat if they are being used to over brake the TV.
Old 08-23-2017, 07:34 PM   #14
2011 22' Sport
Portland , Oregon
I'll try to check the current that is being drawn.
I cleaned the 7-pin connector on the AS (using the kit from AS Life), as if was pretty dirty. I then applied dielectric grease and connected it back to the Prodigy RF box.
Newb question: Should the furnace in a '68 be able to run on shore power? _ally Furnaces, Heaters, Fireplaces & Air Conditioning 4 05-24-2016 10:40 AM
Apparent Brakes Lockup-Dangerous Situation interstateflyer Brakes & Brake Controllers 12 10-26-2013 08:01 PM
Should I be able to hear my fridge on 110V? davida Refrigerators 12 08-05-2006 02:03 PM
Wheel lockup erstrong Brakes & Brake Controllers 2 10-07-2003 12:52 AM
Any newbie worth his/her salt should be able to figure this out for her/himself... Dave Jenkins Our Community 4 07-26-2003 05:41 AM
