Old 08-15-2014, 02:54 PM   #1
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
Self Adjusting Brakes..... can't back up....
Regina and I are 5 weeks into an extended Airstream trip. Prior to leaving Springfield, MO in July my nephew and I replaced the axles on our trailer with new axles and self adjusting brakes.
Everything has been fine until last week when we pulled into McKay's Bend, a BLM campground just SE of Lewiston ID. When I went to back into the spot, I thought I had lost reverse in my TV.... but it was the trailer brakes were preventing me from backing.
I drove around the campground and tried it again, no luck although I was able to move the trailer. I disconnected my plug in and was able to back up as normal.
I had thought by backing up the trailer brakes self adjusted themselves.
We left McKay's Bend and as I was pulling out of the spot, I tried backing up...it was stiff but I was able to move. I told my wife the brakes were adjusting.
When we arrived at Huckleberry Campground on the St. Joe River between Calder and Avery ID, I again found that I could not back up without the trailer brakes engaging.
The route we took north involved dang near every scenic byway in Idaho. I replaced the trailer plug in coming into Mackay ID.... other than that,,,and I am sure I got it wired correctly because my wife took a picture of the old plug and guided me installing the new one.
Any advice? Backing up the trailer brakes engage, going for forward all is ok. Disconnecting trailer umbilical cord allows the trailer to be backed.
I am at hte public library in St. Maries ID eagerly awaiting any and all suggestions!
Thanks!
Jim Lee is offline   Reply With Quote
Old 08-15-2014, 02:59 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Your cable to the trailer is miswired. The backup lights are connected to the brake light e. Worse than that, I would bet that you have no trailer brakes going down the road.
Richard
Old 08-15-2014, 03:06 PM   #3
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Images: 125
I've got good brakes going forward.
But I will check that connector again.
The brakes work fine going forward and it I had no trouble backing up until last week at McKay's Bend.
I backed into the spot at Mackay BLM, at Pink House BLM and other than that, I don't think I backed up at all. Oh yeah, I backed up at Turquoise Garden RV park in Albuquerque.
I paid special attention to installing the new plug....which I got at WalMart for $14 and later found the same plug at Big R in Lewiston for $9.00. It has a metal shank which is easier to put in that the plastic one but it was tough to wire.
Thanks for the heads up.
Old 08-15-2014, 03:22 PM   #4
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Images: 125
I think I got the wires wired up wrong.....I seem to remember the black wire in teh center instead of the purple wire, when I get back to camp I'll check it.
Old 08-15-2014, 03:23 PM   #5
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Images: 125
I'm thinking you are correct.... I am color blind.......red and green..
Old 08-15-2014, 03:24 PM   #6
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Chances are the backup light wire is powering the brakes.
Old 08-15-2014, 04:56 PM   #7
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Can you backup with the 7 way unplugged?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-16-2014, 02:53 PM   #8
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I'm color deficient for red/green also. And dyslexic. Fun! I feel your pain!
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-23-2014, 10:14 AM   #9
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Images: 125
Problem solved
The back up wire was not tight into the plug and spark jumped over to the brake wire
I had replaced the plug outside of Arco NM and never had to back up until McKay's Bend ID.
Now we're heading west out of Mt Rainier towards the Washington Coast.
Old 08-23-2014, 11:55 AM   #10
1966 22' Safari
Weatherford , Texas
Glad you solved it. Have a great trip!
DEXTER Self-Adjusting Brakes slowmover Brakes & Brake Controllers 10 07-14-2017 08:33 PM
2010 flying cloud self adjusting brakes Blazer62 2009-2015 Flying Cloud 0 05-06-2013 10:10 PM
2010 flying cloud 20' self adjusting brakes Blazer62 Brakes & Brake Controllers 0 04-21-2013 12:56 AM
Self adjusting electric brakes. Inland RV Center, In Brakes & Brake Controllers 3 05-20-2009 05:51 PM
