Old 11-01-2013, 11:54 AM   #1
Meg
1960 22' Caravanner
Sonoma , California
Searching for old Hadco brake drum...
The trailer had one Hadco drum1086 but not the other.
The mechanic hooked the electric brake to the one and asked me to try to find another Hadco and after he had it he would then complete the brake job.
So far - nada.
Any ideas of where to find a used Hadco drum 12 by 2 1086?
MegHighway1 is offline   Reply With Quote
Old 11-01-2013, 01:56 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I think you will find your item easier with a item description versus a brand name search. As an example; 12"x2" drum with electric brakes and likely for wheel bolts not wheel studs.
Post a pic.
Used drums may be found at a RV wrecking yard. There are several around the country.
The other comment I have is the repair person should be doing this, not you. They are the expert. Now I realize you are seeking a part for a 53 year old trailer.
>>>>>>>>>>>>Action
Old 11-01-2013, 01:58 PM   #3
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Auto Safety House LLC Parts
This place is local to me and may be able to help you as well. Or a similar place close to you.
>>>>>>>>>>Action
Old 11-02-2013, 10:20 AM   #4
Meg
1960 22' Caravanner
Sonoma , California
Thanks Action,
I will do that.
That baby pic is cute and most people find shells on the beaches in Mexico and you found an AS!
Meg
Old 11-02-2013, 12:10 PM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Hadco Engineering, Inc. - Commercial & Military Axles For Over 50 Years.
Perhaps you might have more luck than I in receiving an answer from them per a TT axle/brake enquiry.
Old 11-03-2013, 04:50 PM   #6
Meg
1960 22' Caravanner
Sonoma , California
Thank you for the help.
DirecLink Brake controller... Mexray Brakes & Brake Controllers 123 01-03-2016 08:58 AM
2002 LY 26' - Airstream MH Brake Failure Intruder Land Yacht/Legacy Motorhomes 15 08-11-2012 06:59 AM
Brake controller for an '82 Avion 34V Section8 Brakes & Brake Controllers 17 01-25-2011 07:43 AM
